It is currently Tue May 12, 2026 4:04 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 23, 2011 12:41 pm
Scott,
I echo John's request. Can you share with us the details of your table lift mechanism and the conveyor system. Did you work from plans or conceptualize it yourself?
Cheers!
Rick
PostPosted: Fri Dec 23, 2011 1:19 pm
First name: David
Last Name: Morris
City: McKinney
cphanna -
Thanks for the ideas. It could be removed by unscrewing the pillow block bearings, but then I'd have to re-true the drum. I'm considering that anyway, because I'd like to mount it a little higher. We'll see. Incidentally, I didn't think about how much extra shaft I'd need for a buffer, but that makes sense. I've got about 2" sticking out from each side of the pillow block bearings.
Tai Fu -
Of course, I have no idea where you might find it in your part of the world, but I found it at a place where plumbers go to buy pipe. Surely there's someplace around you that supplies steel. It's probably a dirty, unfriendly place at the edge of town.
David Morris
PostPosted: Tue Dec 27, 2011 4:56 pm
First name: David
Last Name: Wren
State: ON
Zip/Postal Code: M4C 4X5
Back in 1977 I made my own thickness sander, then Grit made one (better of course!) ... years later we wrote it up for Fine Woodworking Magazine ... think you can view it here. https://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=33433
PostPosted: Thu Jan 19, 2012 12:52 am
Sorry to be late adding to this thread. I made my drum sander years ago and found that it sat unused for long stretches (I work slowly), and took up space I could use for other things. So I added a table top to it, with 270 degree hinges, so it could convert to an assembly table easily.
I'll try to upload some images to show what it looks like:
PostPosted: Thu Jan 19, 2012 12:55 am
Here's a couple more shots.
PostPosted: Thu Jan 19, 2012 1:22 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Issue 86 of shopnotes had a plan for a nice drum/thickness sander...Mike
http://www.shopnotes.com/plans/thickness-sander/
Another day, another dollar.
PostPosted: Thu Jan 19, 2012 2:00 am
First name: Nathan or Matt
Last Name: Hampton
City: Dandridge
Zip/Postal Code: 37725
Ted Davis built one of the nicest sanders I have seen. I think there are pics on luth.org. I'll post a link if I can find it. I'm almost done with mine, and I haven't spent a penny. I just couldn't justify spending $900+ on a large drum sander.
PostPosted: Thu Jan 19, 2012 4:08 am
Has anyone built a homemade belt thickness sander, which is supposed to remain cool and avoid the plugging of the grit?
PostPosted: Sun Jan 22, 2012 10:16 am
John Killin wrote:
Scott A wrote:
Shop made with conveyor, no pushing. It did have a motor...but now I crank by hand. [headinwall]
Also, I tried to use a 5/8 shaft for the drum...now I have a 1" shaft. [headinwall] [headinwall]
Anyway it works great and I use it all the time.
SA
Scott,
Can you walk us through some of the details on your sander? It looks like you have the raise\lower mechanism for the table working at one end. Are you pivoting the table at the other end or are you raising the table at 4 points?
How wide is your drum?
I like what you have setup here with the feed belt for the table. What are you using for the rollers?
Sorry Guys, I didn't see this. The work is crude but it works great.
The front raise\lower is Acme's chained together. There is a top and bottom steel beam below the carriage with brass bushings all around.
PostPosted: Sun Jan 22, 2012 11:41 pm
Last Name: Butler
City: Caledon
Zip/Postal Code: L7C 1S3
Hi Scott
I too am in the process of designing a sander and have a few questions you may be able to help me with regarding roller size.........
Several years ago, while searching a local scrap yard, I found the remains of a roller/conveyor system that was used in our beer stores. I was able to salvage several rollers both solid stainless and tube stainless, complete with pillow block bearings.
These rollers are 24inches long and have a diameter of just over 3inches. In all my previous readings I see that most rollers are in the 5inch + size and was wondering what your experience has been with your 4inch roller.
Do you see any problems with a 3inch roller??
I would also be interested in knowing at what approximate rpm or fpm you are running your sander at.
Any recommendations would be greatly appreciated!
Thanks.
Michael
Users browsing this forum: pullshocks and 254 guests
