It is currently Wed Jul 30, 2025 2:26 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jan 27, 2012 1:23 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
For wood binding, which is all I use, taking off the inside edge and making sure the binding closely fits the contours does the trick just fine. I like wide rubber bands, #107. Two tied together works well for guitars and single bands are good for smaller instruments like the ukes shown here that I bound yesterday.They available from Amazon if you can't find them at your local store. Titebond Original should work for all your needs. For multiple purflings, it's best to use a small brush and spread the glue just a little ahead of where you are working. Keep a rag and some water handy to get the dried, caked glue off your hands as you work.
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Fri Jan 27, 2012 1:31 pm
Last Name: Ensor
City: Springfield
State: Missouri
letseatpaste wrote:
You can do it with TB1, but not on an old joint. If it's a day or two old I think it works okay, I usually try to reheat and reset the joint as soon as I'm aware there was a problem. I wouldn't do it with anything critical/structural, but I have been able to reduce or close gaps in binding like that.
+1! I let my binding sit for about 1.5 hours and then check for anything that needs to be touched up. If you wait too long, you might as well start over.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Fri Jan 27, 2012 3:11 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Wow Bob, that's some prolific uke bindery you've got going on! I feel accomplished if I bind an entire single body in one day [clap]
PostPosted: Sat Jan 28, 2012 1:53 am
Last Name: Gleason
City: Kurtistown
State: Hawaii
Beth, It may look impressive, but it's not really. It's just a matter of having the tools and a method. I've been doing this long enough that I've standardized some things and that makes the process easy. I make all my guitar bindings or uke bindings the same thickness, so it's easy to grab the correct cutter and cut the right ledges first pass. Same thing for the purflings. I know the right cutter to use for the various different purflings I normally use. I don't need to check to see if my bindings and purflings will fit anymore. They just will. As far as how much you get done in a day, well doing binding is mostly a matter of waiting for the glue to dry. Might as well do more instruments at the same time. It takes an hour or so for the Titebond to set up enough, so you might as well be binding another instrument. Ain't nothing hard about making instruments. Anyone with patience gets there, although quite a few builders like to add smoke and mirrors to make it look hard.
PostPosted: Sat Jan 28, 2012 5:39 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Todd, how long do you leave your bands on with the fish glue....I just got some and wanted to try it on bindings next time.
PostPosted: Sat Jan 28, 2012 7:56 pm
What do you guys think of Mike Doolin's binding jig? Worth making? Unnecessary when you can just wrap around the guitar? What are your thoughts?
http://www.doolinguitars.com/articles/bindrope/
PostPosted: Sun Jan 29, 2012 8:49 am
I really like this technique Todd, and I'm becoming a big fan of fish glue myself, with the exception of jointing spruce tops. Not having great success there, but everywhere else.
So tell me, where does one get these giant rubber bands that y'all are using?
Don
PostPosted: Sun Jan 29, 2012 9:35 am
First name: rasmus
Last Name: erlemann
Country: Estonia
Don
I simply visited a bike repair shop and picked up couple of punctured inner tubes. Just cut them up into long 2cm~ wide strips and they work really good.
PostPosted: Sun Jan 29, 2012 9:41 am
Last Name: Ensor
City: Springfield
State: Missouri
The problem I see with this jig is that you can only do one quarter of the guitar at a time and the rope is only holding the binding down in the channel. It is not assisting in holding in toward the sides. Seems to me like the binding could twist more easily and not sit fully flush in the channel.
PostPosted: Mon Jan 30, 2012 1:40 pm
Todd, how are you holding the fixture? Vacuum?
I need to read up on fish glue.
PostPosted: Mon Jan 30, 2012 5:52 pm
Todd, disregard my question. You could just tack a block to the back and mount in a vise.
Just placed an order for fish glue with Lee Valley. Lots of good info in the archives!
PostPosted: Fri Aug 24, 2012 10:36 am
Last Name: A
Todd - what size rubbers bands are you using in the picture ? Seems like rubber bands would be easier to handle than 50' of surgical tubing - I am not fond of the tubing - if the bands work out - I would sell my tubing as well.
PostPosted: Fri Aug 24, 2012 10:42 am
I have some of these, although I haven't used them yet...
http://www.ebay.com/itm/40-INCH-RUBBER- ... 500wt_1315
Users browsing this forum: Bing [Bot], jfrench, pullshocks and 26 guests
