It is currently Mon May 18, 2026 4:14 pm
PostPosted: Tue Feb 21, 2012 2:26 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Kyle and I want to start doing deflection testing - and I sure could use some help on coming up with the items we will need to purchase to make this happen.
Also - while I'm at it - what do you use for a gram scale? I see an inexpensive one at HF - but I want accuracy over price (to a certain point)
thanks
P A U L B U R N E R
Burner Guitars
PostPosted: Tue Feb 21, 2012 6:26 pm
I use our kitchen scale. Any digital scale from Sir La Table or another similar store should work.
PostPosted: Tue Feb 21, 2012 8:20 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
The key item is a dial or digital indicator. Both the HF-level ones have been fine for me. I prefer a dial as I can use it faster, but others like the digital for the zero button. 1" travel is plenty.
Also 1-3 weights. For the longitudinal (stiffer) direction, a steel bar around 14-17" long, with weight around 5 lb works well. It helps if it's narrow (~1") and doesn't roll. For the lateral direction, I use a a 0.9 lb piece of angle-iron. A 0.110" Sitka top will deflect in the neighborhood of 0.12" - 0.20" with those weights and typical spans. If testing half-panels, change the 5 lb to ~2.5, and the 0.9 to quite a bit more. I also use the 0.9 lb weight as a 'tare' weight for longitudinal testing, to remove twist-warp in the panel before testing with the 5.
The rest is wood and fasteners. Particle board, MDF, or another stable wood helps.
There are lots of good, low-$ digital scales on ebay. I've not tried the HF, but the others I've tested have all been very accurate, around 0.1%. The button-feel quality varies by model. Digiweigh is one brand I like (1000BX and postage models... I've not tried their others, though).
David Malicky
PostPosted: Tue Feb 21, 2012 11:59 pm
I do the same as David, but I put the indicator underneath and use a weight that rolls so it is self centering. You do want the weight to be at least as wide as the board you're measuring. And the pre-weighting helps with consistency.
Mike Lindstrom
PostPosted: Wed Feb 22, 2012 12:31 am
Last Name: Burner
City: Lincoln
State: Nebraska
Can you explain this pre-weighting please.
P A U L B U R N E R
Burner Guitars
PostPosted: Wed Feb 22, 2012 1:11 am
If you're trying to measure the deflection of a top, you'll lay it across the jig with a measuring device in the middle. Say you're going to see how much it deflects when a 5 pound weight is placed on it. Pre-weighting is putting a small weight (say a half pound) on the top and zeroing your gauge there. It takes up any slack in your system and gives you a more consistent starting point for your measurement. Then you measure by adding your standard weight in addition to the
I don't know if it is valid from an engineering standpoint to produce real, accurate data, but measuring for consistence from top to top, it seems to work. It at least gets me in the ballpark.
Mike Lindstrom
PostPosted: Wed Feb 22, 2012 1:17 am
First name: Trevor
Last Name: Gore
City: Sydney
Yes, it is valid from the engineering standpoint because you've got a linear elastic system (unless you load the panel beyond its elastic limit...).
Below, you can see how Brian Burns does things (scroll down to near the bottom of the page):
http://www.lessonsinlutherie.com/woodtestingandvoichirez.html
You might want to consider tap testing, too. Just as accurate, much quicker. Then have a think about how you're going to use the data.
http://www.goreguitars.com.au
PostPosted: Wed Feb 22, 2012 4:34 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Links to dial or digital indicators for deflection testing would be helpful please.
P A U L B U R N E R
Burner Guitars
PostPosted: Wed Feb 22, 2012 4:55 pm
First name: David
Last Name: Malicky
We mostly use Enco's Economy 1" indicators and they've been fine:
http://www.use-enco.com/CGI/INPDFF?PMPAGE=331
HF's are probably similar:
http://www.harborfreight.com/1-inch-tra ... r-623.html
Or ebay:
http://www.ebay.com/itm/1-DIAL-INDICATO ... 0465053594
I've used 1 HF digital--it's been good, too:
http://www.harborfreight.com/1-inch-sae ... 93295.html
David Malicky
PostPosted: Wed Feb 22, 2012 7:00 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
David Hurd also has a lot of good information on his site. Here's the info on static
deflection measurements, but look at his other information as well.
http://www.ukuleles.com/Technology/statmeas1.html
I use HF digital indicators and scales, and haven't found them to be inaccurate, at
least in the measurement ranges I'm using. The technology is pretty cheap to
buy these days.
Gene
Users browsing this forum: No registered users and 362 guests
