It is currently Tue Jun 09, 2026 7:54 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Fret Slotting Tools
PostPosted: Tue Feb 21, 2012 2:59 pm
two dogs wrote:
Terence Kennedy wrote:
two dogs wrote:
I started with the LMI blade and stiffners, but the unthreaded portion of my tablesaw arbor is too short to handle the stiffners, and the blade slipped into the threads. Had to manually align the blade each time. Major PITA. Now i'm using the StewMac blade.
I've had that same issue Steve and just lived with it. So that hollow ground StewMac blade works just as well without the stiffners?
Terry
Yup.
TK
PostPosted: Tue Feb 21, 2012 6:22 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
BTW, I thought the price of the SM blade was high till I realized what kind of processing it went through. Most good table saw blades are in that range anyways.
PostPosted: Tue Feb 21, 2012 7:22 pm
First name: Mark
Last Name: Schrier
State: Washington
I am currently using the LMI blade with stiffeners. When I first tried it, the blade slipped into the threads on the arbor. This made it wobble up and down,and the only way to check the height of the cut was to make sample cuts to find out where the 'high point' was. After cutting the first fretboard this way, the wood residue on the blade only appeared on the few high teeth that were actually doing the work.
To remedy this, I applied Bondo tho the first couple of threads of the arbor and trued it up with a bit of sand paper when cured. This works well and doesn't get in the way when I switch to a standard blade, although I need to add a spacer between the dampening washer and the nut. This is so the threads on the nut don't cut the Bondo out .
The up side is that the thin blades are a lot cheaper to replace when that time comes.
Mark
A world without music would Bb.
PostPosted: Wed Feb 22, 2012 10:11 am
First name: Wes
Last Name: Young
City: NEWFIELD
Zip/Postal Code: 14867
Has anyone had an issue with the arbor using this blade on Delta Unisaw? The saw is about four years old years old.
