It is currently Sat Jun 13, 2026 9:58 am
 Post subject: Radius Dishes
PostPosted: Wed Mar 14, 2012 10:55 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I am in the market for radius dishes and I am a bit confused, or I guess I should say uneducated about them. Stew Mac sells the following:
15-foot radius for Martin backs
20-foot radius for modern guitar backs
28-foot radius for modern guitar soundboards
40-foot radius for Martin soundboards
I am curious why the change in radius for modern guitar versus Martin. Does this change in radius really make a difference in tone and structural integrity? I am planning on building my first guitars closely based on Martin guitars so should I go ahead and get the Martin radii or is it better to get the modern radii? Any suggestions on a few all around radii to get? These things are expenses so I'm hoping I can get just one for the top and one for the back. Thanks for any advice.
 Post subject: Re: Radius Dishes
PostPosted: Wed Mar 14, 2012 11:07 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Either way. I guess if wanting to stay true to Martin and that is their standard then do that. My dishes range from 60ft to 24 ft on the top and 30 ft to 15 on the back. You can have what you want. If just starting then suggest stay with those by Stew Mac No reason for that other than they are proven for quality sound over the years. Once you have done some guitars and want to check out others then go for it.
PostPosted: Wed Mar 14, 2012 12:46 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
For the dish with smaller radius such as 25' which I have been using, I found serious issue with gaps under the fretboard unless a very high neck angle is used. I had to shim the fingerboard in order to make the gap disappear.
So that's a reason for me to use a flatter radius for the top.
Typhoon Guitars
PostPosted: Wed Mar 14, 2012 3:02 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Todd Stock wrote:
28' radius for everything but the UTB (60') gives me a 1.5 degree neck angle and 1/2" string height at the saddle. I don't have a 60' dish - i just glue in the 60' radius UTB on a flat surface and it ends up giving me what I want.
Todd, do you flatten the rim north of the waist to match the flatter upper bout or do you just sand the whole rim to 28' and get what you want from the flatter brace?
Bryan Bear PMoMC
PostPosted: Wed Mar 14, 2012 3:38 pm
Martin backs are not 15'. Closer to 20'
PostPosted: Wed Mar 14, 2012 4:30 pm
The radius has little to do with tone. I culled my disk inventory to 28 for top and 15 for all backs. the key for the top is to match the neck angle so you have a flat and true fretboard plane with about 1/2 inch string height at the top .
PostPosted: Wed Mar 14, 2012 9:40 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
You got me on that one Todd. Are you saying that the back on the D and M are a 25' radius? And going how far back in time? Especially since their tops are so flat also. I use 20' for my 000/OMs. Wish John Arnold would add on this as I remember he and Willie Henkes talked about a compound radius on the backs of older Martins. Meaning that it was different longitudally than across the back and they were braced up in fixtures rather than dishes. Somewhere on the UMGF there will be a thread showing pix of the fixtures and more discussion.
Tim
PostPosted: Thu Mar 15, 2012 4:41 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
I'm about to use the Grellier plans to build an OM. The plans have a 25' radius on top. If I used a 28' radius would I have to change the bracing at all? I could then use Todd's method of the 60' UTB.
We are all in the gutter but some of us are looking at guitars.
PostPosted: Thu Mar 15, 2012 6:41 am
No need to change the bracing plan based on a 3 foot difference (which is almost nothing over the span of a brace) in radius.
PostPosted: Thu Mar 15, 2012 7:24 am
backs on Martin dreds start at 20 foot radius and 000 at 15. Also a note is once they are glued they tend to change a bit from RH. As for the top there is a slight radius and a 1 1/2 degree incorporated to the top. As a repair center for Martin I was invited to go to the CF Martin repair summit last year and this is the equipment that they use .
I was allowed pictures and to study this . It is quite the machine. I wish I had one.
PostPosted: Thu Mar 15, 2012 8:13 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
^^^ Nice!!!!
Beats the crap out of "driving the bus", right John? :D
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Thanks guys. I think I will go with a 28' for the top and 15' for the back for now. Has anyone bough radius dishes from Luthier Suppliers? http://www.luthiersuppliers.com/products/p4.html It seems like their dishes are well made and fairly priced.
PostPosted: Thu Mar 15, 2012 8:40 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
John, are those holding fixtures pneumatically actuated? That's pretty cool, although only making a couple guitars a year think I can still hold mine by hand. :)
Tim
PostPosted: Thu Mar 15, 2012 3:42 pm
there are pneumatic cylinders there so I think so. It is a nice chunk of engineering
PostPosted: Thu Mar 15, 2012 4:42 pm
I just ordered a set yesterday [:Y:] Good stuff. Tracy made my first few as well.
Users browsing this forum: rbuddy and 39 guests
