It is currently Sat Aug 16, 2025 7:34 pm
 Post subject: Supersoft Procedure
PostPosted: Tue Apr 10, 2012 10:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Please tell me how u use Supersoft.
 Post subject: Re: Supersoft Procedure
PostPosted: Tue Apr 10, 2012 11:37 pm
Based on reading online, I spray it down well and wrap it lightly in foil to slow evaporation and keep the stuff off my bench and anything else. Let it soak in overnight. Then bend in bender with blanket. Limited experiences, but so for so good.
Mike Lindstrom
PostPosted: Wed Apr 11, 2012 6:47 am
I lean the wood against a protective backdrop (freezer paper taped to a cabinet with more on the floor), spray both sides liberally and just let it soak in and dry.
I've had good luck with this method but I would be interested to see if anyone has tried this versus spraying and wrapping. I'd like to know if there is a significant advantage to wrapping the wood in foil to slow evaporation?
PostPosted: Wed Apr 11, 2012 7:17 am
State: ON
I spray a light coat over each side and then put the two sides together in a plastic bag. I let them sit over night and absorb the supersoft. I bend the next day.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Wed Apr 11, 2012 7:59 am
I haven't compared it. I just figured if I wanted to soften up the wood, it would be better to have it soak all the way through instead of going away.
Not a big fan of the smell. Does anyone know if I should be doing that in a booth?
Mike Lindstrom
PostPosted: Wed Apr 11, 2012 8:15 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Todd Stock wrote:
Spritz to a shiny, wet surface and allow to drain and dry. Just bent, straightened, and rebent a highly figured mahogany side without drama...really like the stuff in my coffee as well.
It's nice to know it has many uses.
PostPosted: Wed Apr 11, 2012 9:24 am
First name: John "jd"
City: Santa Barbara
The stuff is 99% DiEthylene Glycol MonoEthyl Ether. It should wet easily and evaporate very slowly which is likely why it works pretty much the same if you wrap up or not.
...not especially dangerous, but I would not recommend putting very much of it in your coffee.
-jd
PostPosted: Wed Apr 11, 2012 11:50 am
Last Name: O'Melia
City: Huntsville
State: Alabama
-jd
Hmm. Better wear gloves (and not flavor ur coffee with it). According to Wikipedia: Recent study suggests that occupational exposure to glycol ethers is related to low motile [tadpole] count in men,[2] but the finding has been disputed by others.[3]
PostPosted: Wed Apr 11, 2012 1:54 pm
It's a floor cleaner AND a desert topping! :mrgreen:
PostPosted: Thu Apr 12, 2012 9:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
So a question. I try very hard to keep material exposure to a minimum (DNA, shellac, epoxy). This stuff is a new substance that appears to integrate with the wood. Does heating it eliminate it? Or does it stay behind?
PostPosted: Thu Apr 12, 2012 9:23 pm
City: Santa Barbara
it is a high boiling point solvent that will completely evaporate out of the wood over time. Heat from the bender greatly accelerates this.
This family of solvents does have a long history of reproductive damage in both men and women. As always, read the MSDS and decide for yourself. You can also take an additional step and read the MSDS on the active ingredients if that makes you feel better.
-jd
PostPosted: Thu Apr 12, 2012 9:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks. I'm done reproducing. I love my kids. But at times I do question my earlier ambitions in that department.
Mike ;)
PostPosted: Mon May 28, 2012 1:57 pm
City: Calgary
State: Alberta
I'm laminating some sides for a cutaway guitar (Indian rosewood & Alaskan yellow cedar following Bogdanovich's book modified for a cutaway). My plan was to soak with Supersoft, then pre-bend on a hot pipe before putting the veneer slices into my laminating form.
I doubt the Supersoft will interfere with the glue up (Titebond), but thought I'd check. Do you let the pieces dry for a while before gluing?
PostPosted: Mon May 28, 2012 3:43 pm
I always let them dry overnight before I bend.
PostPosted: Mon May 28, 2012 4:51 pm
Last Name: Beaver
City: Lake Forest
I've only used it on some ornery Sapele (brittle batch). I followed John Halls procedure Best as I can remember: Spray both sides, let it soak awhile then stack between paper to dry and bend the next day.
The jury's still out on if it helped all that much.
The only problem I saw and haven't seen anyone mention it is it bleached the wood! I had to use a little amber on the sides to bring them back to the color of the back.
Joe Beaver
Maker of Sawdust
PostPosted: Tue May 29, 2012 7:46 am
I've experienced some color leaching out of the wood but so far it hasn't been anything I couldn't deal with fairly easily.
PostPosted: Tue May 29, 2012 12:34 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
Will any veneer softener work or does it have to be Supersoft?
Users browsing this forum: Bing [Bot] and 11 guests
