It is currently Sun Sep 21, 2025 1:08 pm
PostPosted: Sat Jun 02, 2012 3:34 pm
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
I am building a 0-size now, and I wish to use an X-brace. The guitar I drew the plans from used ladder bracing, and had steel strings on it for many years, but I would feel better about the X-brace. I plan to use lights or silk-and-steels. By the way- is it even necessary to use an X-brace with silk-and-steel strings?
Could y'all tell me if I'm on the right track? I kept the bridge in the original place, and basically drew the X so that the lower arms support the wings of the bridge, and intersect 1 3/4" below the soundhole. Then I put in single finger braces 3" below the upper arms of the X, and put the tonebars where they would normally fall for an OM guitar.
Here are two pictures of both my bracing proposition, and my template with the ladder bracing. Hopefully they are clear enough.
Oh, and the bridge plate will extend about 1/4" behind the bridge, so it won't be a perfect trapezoid the way I have it drawn here.
PostPosted: Sat Jun 02, 2012 3:44 pm
State: Tennessee
Here is a Martin O size I'm building.
PostPosted: Sat Jun 02, 2012 4:11 pm
Looks right to me...
PostPosted: Sat Jun 02, 2012 5:30 pm
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
Thank you for your input, and for the pictures.
Would you recommend moving the upper tonebar down away from the bridge plate, and changing the angle so that the outer end is closer to the X? I just don't want to reinvent the wheel if these variables have all been tried before. Will that make a noticeable difference?
PostPosted: Sat Jun 02, 2012 6:07 pm
Actually you are over braced . You can use 1 finger brace and 1 tone bar. I have one that is how Martin braced it.
PostPosted: Sat Jun 02, 2012 6:31 pm
State: Tennessee
John I believe I got my O tracing from you.
PostPosted: Sat Jun 02, 2012 6:43 pm
State: Tennessee
Well John is right, I was using the wrong tracing. Here is the Martin O size tracing.
PostPosted: Sat Jun 02, 2012 7:06 pm
thats the one that will work the best. They are great guitars
PostPosted: Sat Jun 02, 2012 7:21 pm
Here's one of mine from a size 0:
This was in the same file so I had to throw it in. One of Stephan Boone's planes.
PostPosted: Sat Jun 02, 2012 7:36 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
These small body guitars aren't so wide at the low bout, so they don't need that much transverse stiffness. That said, only one small tone bar is enough, or you can use a fan-brace hybrid system. I mean replace the tone bar by 2 or 3 fan braces. That what's on the plan I drawn for a Size 1.
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sat Jun 02, 2012 8:45 pm
First name: Freeman
Last Name: Keller
The size 0 that I built had one tone bar and scalloped 1/4 inch braces. Works great with light gauge strings (I'm not a fan of silk and steel). Remarkably loud and quite well balanced for a small guitar.
PostPosted: Sun Jun 03, 2012 12:16 am
Gotta love them Boone planes! Steve, what's going on near your truss rod hole with the dark patch? Also, is it a lefty?
PostPosted: Sun Jun 03, 2012 12:23 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
This is a 1932 Martin 0-18...it has two...
PostPosted: Sun Jun 03, 2012 10:49 am
A 12 fret Zero only needs, and uses, one tone bar and finger brace. Not sure, but the original poster appears to be building a 12 fret?
PostPosted: Sun Jun 03, 2012 11:17 am
I was moving a bit too fast when I drilled the hole in the brace for the truss rod and got a bit of tear-out around the hole. Not a big deal but it annoyed me so I stuck a slice of rosewood on it, drilled it and blended it in. This guitar is a righty. It is based on an 0-16NY that I bought new in '68 that I still have - a superb finger-style guitar and that is my goal with the new one.
PostPosted: Sun Jun 03, 2012 11:38 am
In which case, your tone bar is on the wrong side...
Not really an issue, but just sayin'....
PostPosted: Sun Jun 03, 2012 6:20 pm
Not sure why it ended up there but it wasn't on purpose. I figured it probably wouldn't matter. The top is now on a mahogany box with black plastic binding - the plan is that it will be my shop guitar.
PostPosted: Mon Jun 04, 2012 10:54 am
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
Thank you all for your help! I plan to get right on bracing this little top tonight!
Mario is right- it is a 12-fret. This will be a little smaller even than a 0, though- I compared my template with the Martin spec sheet, and mine will be 1/2" shorter in length, and a 1/2" narrower across the lower bout.
PostPosted: Mon Jun 04, 2012 6:03 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Size 1?
PostPosted: Mon Jun 04, 2012 7:54 pm
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
After searching further for Size 1 dimensions, I found the overall body width of 12 3/4 inches, and I wasn't able to find a length.
This guitar I'm trying to build is 18 3/4" long, 13" at the lower bout, 7 1/2" at the waist, and 9 1/2" at the upper bout. That seems to put it between a Size 1 and a 0, right? At least in Martin terms. I drew the plans off an antique Washburn. I don't know what they called it.
Just to double-check: How's this bracing pattern now? As nearly as I can tell, it should work, based on the tracing above. The "improvements" are done in red, in case it wasn't obvious.
Thanks again for all your help. I'm kind of excited about this little project for sentimental reasons.
PostPosted: Mon Jun 04, 2012 8:18 pm
State: Tennessee
I say go for it. Uh that top looks a lot like cardboard laughing6-hehe
I went ahead and went with my dual tone bar, 4 finger braced top, size O. I did some additional carving so we will see. Its a box as of this morning.
PostPosted: Fri Jun 08, 2012 4:45 pm
First name: Sean
Anyone know where I could get a drawing of this 14 fret O size guitar? I love this size, just finishing a 12 fret 0 size, and would love to build a 14 fret in the future, but don't know where to get a drawing.
change isn't synonymous with improvement
instagram.com/bucketguitars/
PostPosted: Fri Jun 08, 2012 4:52 pm
State: Tennessee
John Hall at Bluescreek has them
PostPosted: Fri Jun 08, 2012 4:58 pm
First name: Sean
Thanks, I'll check with him!
PostPosted: Fri Jun 08, 2012 6:55 pm
The '25 0-18 in my shop has 2 tone bars, but it is the lightest guitar I've ever seen. I had to put weights on it to keep it down on the bench.
Users browsing this forum: bftobin, Bing [Bot] and 31 guests
