It is currently Sun Sep 21, 2025 1:30 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 08, 2012 1:26 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
+1 for POC, never used it,Am sure that once spanish cedar an h mahog become less available and more expensive that luthiers and manuf. will be looking for alternative woods
PostPosted: Fri Jun 08, 2012 2:45 pm
First name: Wendy
Last Name: W
State: Arizona
Thanks Alexandru. I meant lighter in color, not lighter in weight.
PostPosted: Fri Jun 08, 2012 4:57 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Ernie, I was haveing a hard time visualizing how the rays would express themselves once carved in a neck profile. Your pic helped alot. I was not thinking about the fact that (unless the blank is 100% bang on quarter) you won't be able to keep the figure running exactly down the back of the neck once you start carving. I now have a better idea of what type of neck construction I should use (depending on the effect I want for a particular project). the wood itself seems perfect for necks -- especially if you want to use midwestern woods -- and I anticipate using it a lot in the future.
Bryan Bear PMoMC
PostPosted: Fri Jun 08, 2012 5:53 pm
Here's a Bashkin with a Port Orford Cedar neck. I'd love to be able to find some flat-sawn stock for laminated necks like this. I'm a big fan of maple for the look, but almost never use it because of how heavy it is. Port Orford Cedar offers the same look while being substantially lighter in weight. Sounds like the best of both worlds to me.
PostPosted: Fri Jun 08, 2012 6:28 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Santa Cruz sycamore:
PostPosted: Fri Jun 08, 2012 7:11 pm
First name: William
Last Name: Snyder
City: Brooklyn
Considering weight and stability I feel I can pretty safely say I'll never do a sycamore neck...but WOW, that looks sweet.
PostPosted: Fri Jun 08, 2012 8:11 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
The sycamore I have handled (not a huge smaller size) has not been too dense -- lighter than walnut and maple. I think it gets a bad rap on stability too. I think that comes from it being difficult to dry properly especially if not quartered. The stuff I have in my shop doesn't seem to have moved. Admittedly, i have not yet used it for a neck so I could be in for a rude awakening.
Bryan Bear PMoMC
PostPosted: Fri Jun 08, 2012 8:56 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
John love the gorgeous figure on that gtr . Bryan I/m a believer in syamore especially 1/4 sawn.I have stock that is 16yrs old and stock that is 6mo. old .Once it dries out abt 1 yr to the inch,it seems to get more stable
PostPosted: Fri Jun 08, 2012 9:27 pm
First name: Greg
Last Name: B
City: Los Angeles
Prima vera AKA "white mahogany" might be worth considering, if the idea is to make a mahogany looking neck that happens to be blonde. I'm not sure why no one has mentioned this.
POC has better stiffness to weight numbers, but no doubt either timber could be made to work.
PostPosted: Sat Jun 09, 2012 6:31 pm
Alexandru Marian wrote:
""Naturally lighter than Spanish cedar" - that's the likes of WRC...balsa...paulownia...you don't want these for a neck. "
I think he's using 'lighter' in the sense of color: not as dark rather than not as dense. It's confusing sometimes...
PostPosted: Sat Jun 09, 2012 7:27 pm
First name: Wendy
Last Name: W
State: Arizona
I decided to go with the POC, ordered it this afternoon. I'm looking forward to working with it, although I understand the smell is bad. At least I won't be making a lot of dust by thickness sanding like I would if it was a top. Wendy
