It is currently Sun Sep 21, 2025 1:33 pm
 Post subject: Unruly Monkeypod
PostPosted: Sun Jun 10, 2012 8:14 am
First name: Jason
Last Name: McGowan
City: Corinth
Zip/Postal Code: 76210
I purchased a set of Monkeypod back and sides about 4 or 5 months ago from one of the usual tonewood vendors. When the wood arrived, it had a pretty good twist in the sides, and the back was bowed pretty bad. I assumed that it had just sucked up a lot of moisture on its journey to me. After about 3 months of sitting stickered in my build room with a little weight on it, there was little difference. I then put the sides between 2 pieces of mdf and clamped it to the work bench after I spritzed it with a little water, waited for a week, and then re-stickered. That was about 3 weeks ago. I got the sides out again last night, and the twist is coming back. The build room RH is steady between 38-40%.
What are my options here? I'm not sure how I would use it as it is, I don't think it would even make it through the drum sander properly to get it to the proper thickness. The back is still bowed as well.
Jason McGowan
M&S Guitars
_____________________________
United States of America, looks like another silent night
As we're sung to sleep by philosophies that save the trees and kill the children....
Casting Crowns
 Post subject: Re: Unruly Monkeypod
PostPosted: Sun Jun 10, 2012 9:28 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Some wood just don't wanna be a guitar.
Might be a good experiment to see what happens though.
PostPosted: Sun Jun 10, 2012 9:40 am
You can try heating it with your heating blanket and then clamping it to a thick flat substrate. Sometimes putting it through the drum sander will allow it to flatten out since it's thinner but I'd try option one first. If you go the drum sander route don't take it to final thickness.
Ken Franklin
clumsy yet persistent
PostPosted: Sun Jun 10, 2012 9:53 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I had a piece of cocobolo recently with same problem,,,one half of the back was twisted...I used the heating blanket method mentioned here sandwiched and weighted, for the most part it came out flat...then ran it through the sander and ended up with a a pretty thin, but useable piece , came out to about .080 , braced accordingly ....
MK5acoustics.com
PostPosted: Sun Jun 10, 2012 10:48 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
I managed to flatten out a potato chip Brazilian Rosewood back pretty good with a heating blanket. You can pretty much just bend it straight often times.
PostPosted: Mon Jun 11, 2012 7:51 am
First name: Jason
Last Name: McGowan
City: Corinth
Do you guys think a heat lamp, or a heat gun would do the same? I'm not at the level of having a heat blanket just yet. idunno
Jason McGowan
M&S Guitars
Casting Crowns
PostPosted: Mon Jun 11, 2012 8:32 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Perhaps you could contact the tonewood vendor you got this set from and see if they will send you another one.
PostPosted: Tue Jun 12, 2012 8:04 am
You can try a cloths iron to iron it flat. ;)
PostPosted: Tue Jun 12, 2012 3:30 pm
The clothes iron, set on the wool setting, with perhaps some sort of padding underneath, is a very underrated tool.
Rick
Rick
PostPosted: Tue Jun 12, 2012 4:00 pm
First name: Jason
Last Name: McGowan
City: Corinth
A clothes iron, I do have... That may be a really good idea.
Jason McGowan
M&S Guitars
Casting Crowns
PostPosted: Tue Jun 12, 2012 5:08 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Don't forget the Super Soft. Might just be the ticket. In fact, I bet you can do it without heat if you use Super Soft.
Users browsing this forum: TimAllen and 36 guests
