It is currently Sat May 16, 2026 5:59 am
PostPosted: Mon Jun 18, 2012 3:48 pm
Last Name: Charnock
Country: UK
Is this neck block Ok to use, the grain runs top to bottom ?
J
PostPosted: Mon Jun 18, 2012 4:07 pm
I say yes, the next guy is gonna say no.
PostPosted: Mon Jun 18, 2012 5:00 pm
Last Name: Vallandigham
City: Martinez
The next guy... here I am!
It's traditional (martin style) to have the grain running in line with the sides. That way, you never glue to endgrain, which, as I'm lead believe, is not as strong a joint.
In your configuration, the top and backwill glue to endgrain,and the sides will glue along wiht the grain.
I would not use it, but I'd bet money that you wouldn't have a problem if you did.
How's that for an answer?
PostPosted: Mon Jun 18, 2012 7:06 pm
First name: Tom
Last Name: West
State: Nova Scotia
I don't make blocks in that fashion. I think the grain should run in the same direction as the sides. Two reasons, one as Mickey mentioned re not gluing to end grain and the other is that the sides and block can both move due to changes in RH if the side grain and block grain run the same way. I also think the vertical grain is more prone to a crack due to a bit of trama. Guess that makes three reasons.
Tom
PostPosted: Tue Jun 19, 2012 5:18 pm
PostPosted: Tue Jun 19, 2012 7:39 pm
City: winnipeg
State: manitoba
Country: canada
The Hana Lima book calls for end-grain to be coated with glue about ten minutes before you intend to make the joint with a second coat when you make the joint. This chokes off the end-grain so it can't draw the glue away from the joint.
It works for me.
Bob :ugeek:
PostPosted: Tue Jun 19, 2012 8:48 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Took the words right out of my mouth!
PostPosted: Wed Jun 20, 2012 1:45 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
It looks like mahogany to me, I'd say yes, since mahog is pretty homogenus with grain and strengh. I like a flatsawn surface using bolt-on necks. It spread the washer nut head area out, and resists splitting. Gluing end grain with mahogany isn't that big of a deal. Its really dense and doesn't have the pores to soak up glue or anything. I think it would be find if its a stable piece of wood. I use a glued stack, because I dont have 4 inch chucks of mahogany to work with. Your block looks like the grain might be at a 45 degree. It might just be the cutting marks. I'd use it.
Jason Moe
LaCrosse WI 54601
PostPosted: Wed Jun 20, 2012 8:14 am
Tom
I'll add one more reason to this list though I suppose it depends on your style of building. You will most certainly need to plane a profile into the block to accept the angle the back makes as it mates to the block. Planing end grain is no fun.
PostPosted: Wed Jun 20, 2012 10:49 am
That right there is the best reason I've heard yet.
In the past I used Mahogany blocks like the OP shows with no problems over many years, it is just too stable to cause problems, if well glued. I would saw the back taper in the block, but it always needed some trimming.
I changed to a flat grain orientation several years ago, and it is good, but the OP's question needed a "real world" answer.
PostPosted: Wed Jun 20, 2012 5:56 pm
here's my "real world" experience...
I used to run my end blocks like that, but I started seeing hairline cracks in the ribs on some of them after a few years, and at least one had a crack that went through after many years. Luckily, I discontinued the practice and reverted to running the grain with the ribs, as is the "traditional way" before I had built too many.
There is always a reason for "traditional methods".....
PostPosted: Wed Jun 20, 2012 6:19 pm
grumpy wrote:
I used to run my end blocks like that.....
Mario - just to be sure I understand, when you say you used to run your end blocks like that, I think you mean with the grain running "vertically" so that the end grain contacts the top and back. Is that right? Thanks.
PostPosted: Thu Jun 21, 2012 11:39 am
Last Name: Charnock
Country: UK
Trying to source mahogany blocks at 100mm high with the grain running east to west is proving to be a bit of a mare. Only option is to plant top and bottom which I was trying to avoid
J
PostPosted: Thu Jun 21, 2012 12:59 pm
If building under controlled humidity conditions running the block cross grained to the ribs should be less of a problem. Some people feel it acts as more of a crack stopper when run this way.
Users browsing this forum: Facebook [Bot] and 46 guests
