It is currently Wed Aug 06, 2025 1:40 am
 Post subject: Average weight of Necks
PostPosted: Fri Jun 22, 2012 11:01 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Most of the necks I build for classicals minus the FB fall in the 275-325g range irregardless of species. Correct me if you have different outcomes . For my first steel string I found a beautiful piece of 1/4 sawn red michigan maple from woodcraft abt 13 yrs ago, Planing to use it with a ebony fingerboard.Including the truss rod from LMI what is an approximate weight for a steel string gtr with truss rod? thanks.
PostPosted: Sat Jun 23, 2012 12:27 pm
First name: steve
Last Name: stevens
City: joshua
State: texas
Zip/Postal Code: 76058
Sounds like a nice piece of maple. Yes, it will be heavier than your classic mahogany necks but the body wood and guitar size will influence the resulting weight balance of the completed guitar.
If your steel string will be made of hard maple, rosewood or any one of the heavy weight tropical woods you may not even notice the extra weight of the maple neck.
So I guess the answer is - it depends upon your chosen wood weight and body size.
Where I worry about a guitar being neck heavy I tend to use lighter weight open tuners.
Building for the love of building.
PostPosted: Sat Jun 23, 2012 2:25 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
thanks for the advice , the top is 1/4 sawn fir and the back and sides are malaysian rosewood, .The neck is red michigan maple, not as hard or dense as e , rock hard maple. Are there lighter metal tuners available to counteract the weight , if so who makes them ?? or where can I get them wholesale ??
PostPosted: Sat Jun 23, 2012 4:07 pm
Last Name: Kincheloe
The lightest I know are Gotoh Stealth, which you can get from Shane at High Mountain. They're pricey though, over $100 per set. I doubt he could get them any cheaper without a huge order, but it never hurts to ask. I wouldn't mind getting a few more sets myself if it does turn out that mid-size orders get a discount.
LMI has Gotoh open backs for as low as $40, which should be reasonably light weight, although I've never tried them myself.
There's also the option of minimizing weight on the headstock itself like this beauty by Bob Matthews http://www.luthiersforum.com/forum/viewtopic.php?p=482119#p482119
My 14 fret mahogany steel string necks with two way truss rod, closed gear tuners, and barrel bolts have been pretty ridiculously heavy, even when fairly slim and narrow. Not to mention the relatively large headblock necessary for the bolt-on tenon. It's annoying, especially after experiencing the wonderfully light weight and perfect balance of that coral snake guitar :)
I'm switching to lighter tuners for sure, and probably either dovetail or integral neck, and perhaps a change of reinforcement. Could ditch the adjustable rod entirely in favor of one of these carbon fiber D rods http://dragonplate.com/ecart/categories.asp?cID=130, although they're expensive in addition to losing the adjustability. Or maybe just use light weight woods like Spanish cedar or butternut (if I can find any) with carbon fiber stiffeners and a two way truss rod. Or switch to a single compression rod. Also going to try a 12 fret neck on my next one, which will help too.
PostPosted: Sat Jun 23, 2012 5:09 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Dennis thank you for the heads up .It/s been a long time since I ordered guitar tuners.+1 on the coral snake gtr,it/s a beauty bliss gotta love the lower weight. I disassembled a maple dresser That I picked up off the hwy to lake perry in lawrence .It yielded a lot of soft maple which I figured is = to h.mahog in wt . less all the hassles of pore filling. I bought an el cheapo $17 harboring freight gram scale which I find extrememly useful. I have an old ohaus scale that I used for bowmaking in the past.. I might just put the michigan maple neck on the back burner.Have not installed the lmi truss rod / bolts, since I got so many necks out of that soft maple. I might switch to that instead for my OM build , your thread here reminded me that once all that hardware plus tuners are put in , it/s gonna be one heavy neck.Just laminating my first maple spanish heel style neck.I built a solera abt 6 yrs ago from the courtnall book . but never used it. Need to dish out a 25 ft radius on the solera. cheers . How is the plane coming along? PS as for neck stock 1/4 sawn sycamore is nice, cheap and readily available from jim in g view.Metro has sp cedar but I personally don/t care for the smell, stringy nature, an tearout of the wood while carving , because of the weight, one needs super sharp tools , an pore filling and I/m geting lazy in my old age pizza . Metro had slash sawn butternut , which allegedly is light , but I don/t care for the colour . I really like the peruvian walnut he has , light as h mahog , beautiful colour ,an easy to carve., and IMHO looks stunning.
