It is currently Mon Aug 18, 2025 5:52 pm
 Post subject: Bending Iron or Blanket
PostPosted: Sun Jun 24, 2012 12:44 pm
Last Name: Charnock
Country: UK
There is quite a bit of effort involved in bending on a bending rig with a blanket, admittedly most of the time is spent making forms.
I watched this Video posted by Robbie O'Brian recently
http://www.youtube.com/watch?v=8fEhicNLgxo
It does not seem that bad, when I bend in the rig I don't seem to get that perfect fit in the mold, I like the ideas of bend and check. I just bent some Cherry and Its in the mold but there is some tension in there to get it to fit.
Ideally I would like an iron to fine tune, which got me thinking about using an iron for the whole process.
Any thoughts ?
J
PostPosted: Sun Jun 24, 2012 3:45 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
John,
I'm not the best person to respond, but I'm interested in your question and hopefully you'll get something better than this.
I built a bending machine according to plan but went with light bulbs as the heat source, hoping to avoid the expense of a blanket if I could. Anyway, the machine was not getting hot enough for me, so I thought I would try the bending iron, and I made one similar to that described at the site below, using a 3" outside diameter pipe and a charcoal lighter as the heat source. Didn't really like the idea of an open flame in my garage, so I avoided the propane torch. Anyway the bending iron exceeded my expectations. I think the charcoal ligher was about $12.00 and the dimmer switch was under $10. I actually was able, after some trial and error to get the sides to fit in the mold fairly well; takes a little practice, but you can correct the bend by re-heating. I turn the dimmer switch to about 2/3 power (if you believe the info with the lighter it can get up to 1000F); tried checking temperature with my wife's meat thermometer, but don't think it works too well. Just adjusted so that water droplets sprayed on the iron jumped and vaporized right off. I'm keeping the bending iron, but I did just order a silicon blanket and will be giving the bending machine another go since it looks so lonely sitting on the floor in my garage. Others on the site have mentioned that they use the iron to touch up their sides when they come out of the bending machine. In any case, John, I think you can make an iron pretty cheaply and see how you like it without taking too big a risk. I'm more comfortable with the iron, than I thought I would be.
http://soundsalon.com/Make_a_Bending_Iron.html
PostPosted: Sun Jun 24, 2012 5:50 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
FWIW I do all my bending on a hot pipe. I like it because I am more in touch with the work, and when I do multiple sets I think it is quicker.
Brian
PostPosted: Sun Jun 24, 2012 5:54 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I prefer a bending iron. I actually owned a bending mold system and I Ebayed it after trying it out. I found you still have to sometimes touch the sides up after the mold with the iron because of spring back. I decided to just stick with the iron. I built my iron just using a piece of 2 1/2" by 12" black threaded pipe a flange and an electric barbecue charcoal barbecue starter. I use a router speed control from harbor freight to vary the temperature. I got this idea from somewhere on the web. I used a propane torch before that. Just seems a little safer with the barbecue starter as longs as you remember to turn it off....Mike
Another day, another dollar.
PostPosted: Sun Jun 24, 2012 7:06 pm
I have blankets and a form, but I still use the bending iron for my sides. Not saying it's better, but I do like the process. Might change my mind if the wood is difficult.
PostPosted: Mon Jun 25, 2012 12:06 am
Last Name: Charnock
Country: UK
BBQ starters are not that common in the UK, I have found a source of pipe heaters which could be adapted and would probably be safer.
There are mixed reviews on the Ibex heater, some say it does not get hot enough.
J
PostPosted: Mon Jun 25, 2012 7:03 am
can you send pics of your bending pattern issue. Often it is more technique or the pattern wasn't compensated for the wood that can cause a mismatch.
I agree a iron will help you tweak for irregularities. It is a good skill to have. If you have industrial tooling outlets in your area check out there for heat elements. They are not that expensive.
PostPosted: Mon Jun 25, 2012 10:33 am
I have a fox type bending form with blanket and an Ibex bending iron. I use the bending iron cause I like to do it. If I was trying to make more guitars I would probably use the bending form.
PostPosted: Mon Jun 25, 2012 7:20 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I started with a bending blanket but moved to a hot pipe. I'm just a hobby builder and rarely do the same body shape twice so building bending forms isn't worth it. I get great results with the pipe and it only takes about 20min per side. If you're building many of the same body shape then building forms would probably make sense.
My hot pipe is just a section of iron pipe and a heat gun. Pretty cheap and easy. The nozzle on the Wagner heat gun fits in a 1-1/4" pipe coupling perfectly
PostPosted: Tue Jun 26, 2012 2:32 pm
Last Name: Charnock
Country: UK
I bent these sides on Saturday and just about managed to shoe horn them into the mold hence the reference to tension, I clamped the neck and tail blocks just to keep it all together (no glue). I then spritzed it with water for most of the afternoon and left it in the sun to dry. Every time it dried out I spritzed it again, I didn't have a plan it just seemed like a good idea at the time.
I just removed all the clamps to show you how badly my side fit my mold , guess what .............................
PostPosted: Tue Jun 26, 2012 2:48 pm
Last Name: Charnock
Country: UK
mkellyvrod wrote:
John,
Thanks I am now looking into building a bending iron, heating bands seem like the ideal solution to heat the pipe
http://www.resistanceheaters.co.uk/www. ... fo.php?p=2
These retail for $15.00 so it would not be too expensive to make a couple of diameters
J
PostPosted: Tue Jun 26, 2012 4:13 pm
your fit looks pretty good. One thing is that you want to keep the sides a tad long so you can use the waist spreader to help get the sides dead tight to the sides. Often it is that people trim sides short. There is a technique for that perfect fit and you soon will master that
jh
PostPosted: Wed Jun 27, 2012 12:41 pm
I used blankets and forms for many years. I recently switched to a bending iron for my current archtop build, so my only experience so far with the iron is with maple.
My experience with the bending machine is that the blankets often produced excellent results, but sometimes gave me flat spots, uneven curves, and ripples. I occasionally got cracking in cutaways. Invariably, I got more springback than I would have liked.
With the iron, I did several test pieces of maple (mostly flatsawn curly maple), and then I did the "real" pieces (quartersawn and highly flamed). Every piece bent perfectly. No flat spots, the curves were even, and no ripples or cracking. Absolutely no grain lift on the figure. No springback. The only problems I encountered was on (a) on my first test piece, I didn't use enough water and the wood case hardened before I finished the bend, and (b) on one test piece I got very light scorching (so light I hesitate to call it scorching), but it sanded out very quickly and easily.
The cutaway was pretty tight with the iron, and it took a little while to bend the cutaway side (probably 25-30 minutes to get it perfect). I'm sure it will go faster as I get more experience. The non-cutaway side went pretty fast (10 minutes).
With the bending machine, it always takes longer than what it took me to bend with the iron. The bending itself is faster with the bending machine, but setting up the machine, wrapping the sides in foil, and getting the sides perfectly aligned in the bender all takes time. Not to mention the fact that, once you bend, you have to let it sit there a while to cool before you can use the machine again. Also, I have never been thrilled with the results I get from the machine on cutaways, and it is a pain in the neck to sand defects out of the cutaway.
I'll defer final judgment until I have more experience with the iron. Perhaps I will get less favorable results bending sides for flattops (which are wider than archtop sides), or bending species other than maple. But unless I have a radically different experience on future builds, I'll eventually put the bender up for sale.
PostPosted: Wed Jun 27, 2012 12:46 pm
Last Name: Charnock
Country: UK
Hi You are echoing my sentiments exactly, I don't have that much experience and I have invested quite a bit of time end effort in to building a fox bender. You are correct, you never quite know what you are going to get until it comes out the bender and by then it is too late to correct any mistakes.
J
