It is currently Sat Aug 02, 2025 4:25 am
 Post subject: Belleville washers
PostPosted: Tue Jul 03, 2012 1:30 pm
Anyone got a good supplier for black belleville washers, .255"id?
 Post subject: Re: Belleville washers
PostPosted: Tue Jul 03, 2012 1:43 pm
First name: Ringo
http://www.mcmaster.com/nav/enter.asp?partnum=9712K21
PostPosted: Wed Jul 04, 2012 7:57 am
Gracias!
PostPosted: Thu Jul 05, 2012 9:35 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
any source that ships outside of the US (Mcmaster doesn't)?
Typhoon Guitars
PostPosted: Fri Jul 06, 2012 7:40 am
David, Can I ask what you are using these for? Neck bolts?
PostPosted: Fri Jul 06, 2012 11:24 am
Yes.
PostPosted: Sun Jul 08, 2012 9:15 am
Lex, these are stainless. I was looking for black.
PostPosted: Sun Jul 08, 2012 2:17 pm
First name: Ringo
http://www.amazon.com/gp/product/B002BWOS6C/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0017J1JVM&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1YKFEHQZSTDT3CMYYJ2D
PostPosted: Sun Jul 08, 2012 2:25 pm
First name: Ringo
but seriously, this may work:
http://www.amazon.com/Belleville-Washer ... le+washers
PostPosted: Sun Jul 08, 2012 6:25 pm
First name: Adam
Last Name: Neat
City: Winchester
State: Ohio
The ones in McMaster are regular steel (black) or stainless
PostPosted: Mon Jul 09, 2012 6:10 am
ANeat, if you can show me where they have black belleville's in a .255x.5" format, I'd like to know. They have black ones in a smaller format with ridged surfaces for locking, but not in .5"OD.
PostPosted: Mon Jul 09, 2012 10:37 am
First name: Adam
Last Name: Neat
City: Winchester
State: Ohio
On the link provided above the stainless steel are listed on the far right column, and the carbon steel are listed to the left of that.
Part numbers are 9721k61 9721k62 9721k63 and 9721k64 are all the .255 id .5od .018, .022, .025 and .038 thickness.
Are the carbon steel "black" I cant say for sure, but If I needed black I would get the carbon steel, if they werent black a little cold blueing would take care of it.
PostPosted: Mon Jul 09, 2012 1:44 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
McMaster's descriptions are normally very accurate, so if no finish is specified, I'd assume it is uncoated steel. A black finish would normally say "black oxide".
David Malicky
PostPosted: Mon Jul 09, 2012 6:00 pm
Hi David, these are not listed as black but they are the size you're after.
http://www.fastenal.com/web/products/de ... ku=0123993
These ones are in black, but smaller OD and slightly larger ID
http://www.fastenal.com/web/products/de ... ku=0130152
PostPosted: Sun Jul 15, 2012 12:34 am
Last Name: Buckham
City: Wauchope
Zip/Postal Code: 2446
I searched ebay for them....I got them out of the States to AUS no worries....black and id .255 for neck bolts....
...looking at the amazon link they come from Page Auto....the same mob I got them on eBay through....
