It is currently Tue Jul 29, 2025 8:24 pm
PostPosted: Wed Jul 11, 2012 2:13 am
First name: Philip
Last Name: Marcus
City: Cedar Creek
Zip/Postal Code: 78612
I have a spruce top that was shipped and caught some weather on the way. Shipper replaced the set, leaving me with this extra top. It looks a little like a long potato chip. Is there a reasonable way to flatten these?
PostPosted: Wed Jul 11, 2012 2:20 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Sometimes placing it between two pieces of plywood or something similar and some weight on top can work. But I have come across some woods that no matter what will keep curling up...Mike
Another day, another dollar.
PostPosted: Wed Jul 11, 2012 6:27 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
You might try ironing them and then clamping it... Otherwise it might straighten up once you brace it.
Typhoon Guitars
PostPosted: Wed Jul 11, 2012 12:13 pm
First name: Philip
Last Name: Marcus
City: Cedar Creek
They're resting under some shelving; ironing sounds like a possibility.
PostPosted: Wed Jul 11, 2012 3:34 pm
First name: Aaron
Last Name: Craig
State: Missouri
I've used an iron, cooked tops in the oven, and bent them on a hot pipe and with a heating blanket. Eventually you should be able to get the wood to flatten to the point thinning and bracing will eliminate any remaining warp. After any heat treatment, sticker flat and under pressure for quite a while before you mess with the wood again.
Aaron Craig
PostPosted: Wed Jul 11, 2012 7:25 pm
Last Name: Shanklin
City: Windsor
State: ON
Spritz the concave surfaces with water (Distilled), then sticker. Run an oscillating fan(on low) over the wood and flip and spritz as neccessary. When it reaches equilibrium, it will be flat.....or firewood.
PostPosted: Sun Jul 15, 2012 7:31 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I bought a reject (pretty thin) cherry back once that had a bad
curl/twist. It's been sitting between two flat plates with
weights for about 5 years. It was flat after about three years,
but I'll keep it where it is until I use it.
Gene
Users browsing this forum: Chris Ensor and 16 guests
