It is currently Sat Aug 02, 2025 6:35 am
PostPosted: Wed Jul 11, 2012 4:42 pm
First name: Gorjan
Last Name: Stojanovski
City: Skopje
Zip/Postal Code: 1000
Country: Macedonia
Hi,
I am looking into spray equipment for the first time and can see that many of you use and prefer the turbine systems.
Is there someone that uses the compressor with HVLP gun? If so can you please tell me what a good setup for guitar finishing would be? I am just overflooded with information and would like something that is able to spray nitro and poly finishes.
Gorjan
PostPosted: Wed Jul 11, 2012 4:55 pm
First name: Aaron
Last Name: Craig
State: Missouri
Contact Jeff at http://homesteadfinishingproducts.com/. He'll answer any questions and hook you up with a nice HPLV setup in your desired price range that meets your needs.
Aaron Craig
PostPosted: Wed Jul 11, 2012 6:42 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use both. Either will work fine. I like the turbine for it's portability, we got it mainly to apply coatings on site but I have used it in a booth as well. If you already have the air on hand I would get a Gravity feed HVLP and a good filter/separator. Actually the guns that Harbor freight sells are not bad at all, and at a disposable price. Of course there is something to be said for a really nice gun with a choice of needles, tips and caps but I don't know if I'll ever buy another $300 gun. You'll read much about tip size on the web, the important thing to understand is that you can always reduce your coating to spray with a smaller tip but you can't thicken it to work through a larger one. Solids content of your coatings and how you move the gun will play a roll in tip size as well. Higher solids coatings will need larger tips and need to be hung as heavy as you can without sags to get good flow out. Your coatings manufacturers tech dept. may also be able to provide a general idea of recommended tip size.
Brian
PostPosted: Wed Jul 11, 2012 8:01 pm
First name: Gorjan
City: Skopje
Country: Macedonia
Thank you for your recommendations
I like the one that I should call Jeff, since I already bought his books on the topic he should be the right guy to get advice from :)
Todd, I trust your recommendation and I read plenty of good things about the Fuji MM3 and MM4. If I choose turbine I those are on the top of my list
Gorjan
PostPosted: Thu Jul 12, 2012 11:21 am
First name: Jonas
Last Name: Baker
City: North Haven
State: CT
Zip/Postal Code: 06473
+1 on Todd's recommendation. I took his advice and got the fuji mini mite 3 and it has been amazing. I've only sprayed Nitro so far, but aside from the excellent gun, I love that I can spray nitro in high humidity without using any retarder and I still get a great finish. Thanks again Todd.
PostPosted: Thu Jul 12, 2012 1:09 pm
Ditto what jeb98 said.
Chuck
Users browsing this forum: No registered users and 41 guests
