It is currently Mon Aug 11, 2025 2:46 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
 Post subject: Re: Let't talk blocks
PostPosted: Tue Jul 10, 2012 7:29 pm
Last Name: Vallandigham
City: Martinez
I have my guitars (bought and built) set up with end pins. Why? I guess just because that's how it's "done".
I have my own method for using tapered end pins, I use a reamer to get a nice fit, until the collar is just tall of the guitar, make sure it looks great, then I throw the pin in the case and pull up a chair! :lol:
PostPosted: Tue Jul 10, 2012 7:54 pm
Last Name: Flindall
City: Peterborough
Huh. Well it looks like I may have screwed up the grain orientation on my first custom build. Silly me. I have the grain running vertical on both with end grain pointing to the top and back.
For the tail block, I used a solid piece of mahogany. But I ran a 1" wide dado up the center of the back side that you glue up to the rim. In the dado I glued a strip of Baltic birch ply. It's nice and hidden and that tail block should never split. Mind you I don't think I'll test this theory anytime soon! :)
Rob
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Tue Jul 10, 2012 10:20 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
So what about a cutaway. Is it better to glue the top and back to end grain, or the trebble side?
Bryan Bear PMoMC
PostPosted: Wed Jul 11, 2012 3:29 pm
Last Name: Beaver
I did use Baltic birch for end blocks, al la lerivee. I now use a two piece mahogany block. Grain next to the sides running parallel, the pi
ece toward the neck running 90 degrees to it
PostPosted: Wed Jul 11, 2012 8:16 pm
Been using laminated neck and heel blocks for 20 years. Spruce and mahogany = 1/2 the weight of a solid hog block, no splits to worry about either.
tim...
PostPosted: Thu Jul 12, 2012 4:42 am
Where do you buy your weightless spruce, Tim?
:D
PostPosted: Thu Jul 12, 2012 9:17 pm
Just efficient use of waist waste.
tim...
PostPosted: Fri Jul 13, 2012 12:05 am
Yeah, but you're still bad at math... ;)
PostPosted: Fri Jul 13, 2012 9:01 am
Yeah, but fractions are still pretty tough [for me] to do with both shoes off... [uncle]
tim...
PostPosted: Fri Jul 13, 2012 9:30 am
First name: Big
Last Name: Jim
Well he did have a 40/40 chance to get it right ! laughing6-hehe
PostPosted: Fri Jul 13, 2012 10:43 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
:D
I don't know how Tim does it, but I just put my spruce in a collider, and knock all the Higg's bosons out of it. I thought that was standard procedure.
 Post subject: Re: Let's talk blocks
PostPosted: Fri Jul 13, 2012 8:01 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Todd Stock wrote:
I knocked out a bos'n one time...now that was a bar fight.
Knocking one out isn't enough. If you don't knock them all out, if you leave any mass in the spruce, you'll end up with the annoying upper partial known as the "boson's whistle".
PostPosted: Sat Jul 14, 2012 6:19 am
I use waterproof glue and have steamed apart both M&T and Dovetail joints with no delamination issues. As far as weight is concerned, you be the judge. Granted one block has been beveled but both blocks are the same thickness and their overall sizes the same:
tim...
PostPosted: Sat Jul 14, 2012 11:56 am
The beveling takes a lot of mass off...
Tim, we've made fun of your comment of "1/2 the weight" because it is physically impossible. You've replaced 1/2 the mahogany with spruce. That will lead to a lower weight block, but to be 1/2 the weight, the spruce would have to be weightless... ;) In fact, even if you made the block entirely of spruce, it still wouldn't be half the weight of a solid mahogany block(because spruce isn't near half the weight of mahogany). Even western red cedar isn't half the weight of mahogany...
PostPosted: Sat Jul 14, 2012 12:14 pm
Country: Romania
I think WRC might do it half the time, all wrc I have is in the 300-330Kg/m3 range, while mahogany often 600-650. Some are in the 500s though. Engelmann should be about 360-380, Sitka usually around 430-460 or so.
Build log
PostPosted: Thu Jul 26, 2012 1:57 am
Last Name: Charnock
Country: UK
Here is a block which cut in half and re glued to give avoid end grain top and bottom
[url]
https://plus.google.com/photos/10349537 ... 8246538449[/url]
J
PostPosted: Thu Jul 26, 2012 8:51 am
First name: Coe
Last Name: Franklin
City: Decatur
This may be a good time to take another look at the thread that ran for some time a few years ago about "stress risers", or maybe take another look at the subject in general.
I constantly think about grain orientation and stress risers as being a force to be reckoned with, though I`m no engineer...
Coe Franklin
