It is currently Fri Aug 01, 2025 6:42 am
 Post subject: My rod is too long....
PostPosted: Sat Jul 14, 2012 10:17 am
First name: Jay
Last Name: Swann
City: Austin
Zip/Postal Code: 78739
This is build #2 for me.... It's a 12 fret parlor with a 24.375" scale length. I had originally planned on doing a mortise/tenon neck joint using barrel bolts as you can see I've laid out on the neck. This would appear to work with the Allied 12 fret truss rod. However, I've considered switching to a Mottola et. al. style butt joint neck with anchors in the heel. For that arrangement, it appears that the truss rod would protrude too far out the heel of the neck to be solidly anchored. Thoughts? Workarounds?
Thanks all!
PostPosted: Sat Jul 14, 2012 11:15 am
First name: Big
Last Name: Jim
Stick with orig plan . I find that when I change ideas in the middle , I generally create headaches that I didnt see comming .
PostPosted: Sat Jul 14, 2012 11:40 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
cut slots in the body for the rod, and the fingerboard extension should hide it.
Typhoon Guitars
PostPosted: Sat Jul 14, 2012 12:54 pm
First name: Tom
Last Name: Rein
City: Saline
LMI sells a 12-fret rod that is just a bit shorter than Allied's. I ran into a similar situation with a short scale 12-fret 00. The length of the LMI rod was perfect.
Stay with the happy people.
--Reynolds Large
PostPosted: Sat Jul 14, 2012 1:40 pm
........that's what she said.......
Old growth, shmold growth!
PostPosted: Sat Jul 14, 2012 1:54 pm
I needed a short truss rod, and had a 14-fret Martin 2-way sitting around. Cutting it down was pretty easy.
edit:
Perhaps not so with the Allied rod.
PostPosted: Sun Jul 15, 2012 2:01 am
First name: Maks
Last Name: Lavrov
laughing6-hehe that's what I was gonna say!
Users browsing this forum: Bing [Bot], doncaparker and 41 guests
