It is currently Mon Aug 04, 2025 11:50 pm
 Post subject: Another lacquer question
PostPosted: Sun Jul 29, 2012 9:00 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I usually use either or Deft lacquer or Minwax lacquer. Both are nitro based. I'll always use the same brand lacquer sealer underneath. I happen to have a can of Deft sanding sealer and a can of Minwax lacquer. The local store was out of the Minwax sealer. Has anyone ever had any issues using one brand of sealer under another brand of lacquer? Just want to be sure. If so I'll just pick up a can of the Deft lacquer but prefer not to spend the money if I don't have to....Mike
Another day, another dollar.
PostPosted: Sun Jul 29, 2012 11:39 pm
Last Name: Shaw
City: Philadelphia
State: PA
I guess I'll have to give the vinyl sealer a try.
PostPosted: Mon Jul 30, 2012 5:53 am
You can get better lacquer in a can than deft. Mowhawk Behlen and Jet are actually designed for guitars. Deft is for furniture. All guitars that I finished with these finishes checked in a few years. You can get the Behlen and Jet at Grizzly.
PostPosted: Mon Jul 30, 2012 7:03 am
You can also "self" seal using the lacquer. It takes a few more coats than when using a sealer, but you don't have the transparency and adhesion issues some sealers may create.
PostPosted: Mon Jul 30, 2012 11:06 am
Last Name: Shaw
City: Philadelphia
State: PA
John and Todd and Clay thanks for the suggestions. John and Todd I'm going to give one of these other lacquers a try. and I'm also going to check out the vinyl sealer.
PostPosted: Mon Jul 30, 2012 11:28 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I was able to get Behlen vinyl sealer & stringed instrument lacquer in aerosol at my local Woodcraft.
Kevin Looker
I'm not a luthier.
PostPosted: Mon Jul 30, 2012 11:32 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I agree with John, that there are better finishes to use than Deft...
I used deft on three instruments & all showed checking of the finish after five years.
+1 on leaving your sanding sealer on the shelf. I get much better adhesion (and a better looking finish) using vinyl sealer.
PostPosted: Mon Jul 30, 2012 3:22 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Careful using the lacquer itself as a sealer, not all lacquers are self sealing.
Brian
PostPosted: Mon Jul 30, 2012 5:23 pm
This may be a dumb question, but what makes a lacquer self sealing (or not), and what is the danger of using non self sealing lacquer as a seal coat?
PostPosted: Mon Jul 30, 2012 7:24 pm
First name: Darryl
Last Name: Young
State: AR
Does the grain "pop" nice under a vinyl sealer? How well does it match the refraction index of wood?
PostPosted: Tue Jul 31, 2012 4:52 pm
Last Name: Howard
City: Magnolia
State: Delaware
Not sure what makes the difference in the chemistry, but generally if the manufacturer recommends a vinyl sealer the coating may not be self sealing as lacquer will not burn into vinyl. It's a mechanical bond of some type. Certain glazes and other effects must be done between vinyl sandwich coats to ensure adhesion. Sealers are there to form a bridge between the wood and the finish. When the sealer fails the coating will peel. If the wood was not sealed and the finish can't hang on it will fail and peel as well.
Brian
Users browsing this forum: No registered users and 41 guests
