It is currently Fri Jul 25, 2025 3:58 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jul 06, 2012 12:10 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Gluing the braces back. There will be some major reinforcement in the upper bout.
Typhoon Guitars
PostPosted: Fri Jul 06, 2012 11:29 am
First name: Mitch
Last Name: Johnson
City: Little Falls
State: Minnesota
Zip/Postal Code: 56345
Another great post Tai! [:Y:] Really enjoying it! Eat Drink
PostPosted: Tue Jul 10, 2012 12:04 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Gluing in new heel block. This is a two step process so don't freak out at the number of clamp!
Typhoon Guitars
PostPosted: Fri Jul 20, 2012 1:31 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Back crack has been reinforced, so the box is ready to be closed.
Sorry for the overdue update... I had air conditioning failure in my shop so I had to move my work to other rooms... humidity has built up to a dangerous level and I can't do anything about it until a new AC is installed.
Typhoon Guitars
PostPosted: Fri Jul 20, 2012 2:13 am
That picture of the top looks like it at one point had a fairly large bridge patch going across the width, which some ladder braced guitars had. Did you put any kind of bridge patch on the inside?
Old growth, shmold growth!
PostPosted: Fri Jul 20, 2012 2:14 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Yes it has a very large bridge patch, probably acts as an extra brace given the length of it. I have reused the original bridge patch since the damage around the pin holes are a non issue, the bridge is going to be a tail piece bridge meaning there will be no holes in the bridge, only a slot for the saddle.
Typhoon Guitars
PostPosted: Fri Jul 27, 2012 3:21 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Box re-closed
Neck stripped and ready for finishing
Typhoon Guitars
PostPosted: Fri Jul 27, 2012 11:27 am
Good work, Tai.
YOU DA MAN!
PostPosted: Fri Jul 27, 2012 11:29 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Chris Pile wrote:
Good work, Tai.
YOU DA MAN!
I wish the customer felt that way... he sent me an email telling me that he wasn't happy because I wasn't supposed to refinish that neck.
I got really confused and I didn't check with him if I was supposed to refinish this neck and thought I was supposed to refinish the entire guitar (the neck's original color was a total mismatch with the body anyways, it would have looked odd).
All that work just to get yelled at...
Typhoon Guitars
PostPosted: Sat Jul 28, 2012 6:08 am
Maybe start making up a standard form for repairs noting the work to be performed and having the customer sign it?
PostPosted: Wed Aug 01, 2012 9:59 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Regluing the binding. Used CA for this. Next step will be scraping the binding flush (kind of necessary) and routing a dovetail recess, then repair the purflings and filling in any missing wood on the top.
Typhoon Guitars
PostPosted: Mon Aug 06, 2012 12:27 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Dovetail cut, I actually made a router jig that had tabs on the jig which allow clamping through the soundhole, allowing a more solid mount.
Typhoon Guitars
PostPosted: Mon Aug 13, 2012 3:08 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Body repair complete and ready for finish sanding
Typhoon Guitars
PostPosted: Mon Aug 13, 2012 10:25 pm
Nice work Tia, I think the owner will have a change of heart once its all finished.
PostPosted: Thu Aug 16, 2012 2:59 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Neck fitted and attached
Typhoon Guitars
PostPosted: Thu Aug 16, 2012 7:16 am
Looking good Tia. Any pics of your dove tail jig? Also that's an interesting body shape, I'd be interested in knowing the width of the bouts and waist.
PostPosted: Thu Aug 16, 2012 7:22 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
The dovetail jig is a piece of plywood with a V bandsawn into it that matches the dovetail on the neck. The size is then adjusted by moving the piece up and down to get the right size. A piece of wood is then glued at the right angle to this piece to allow me to clamp the jig onto the guitar body to cut the dovetail. The dovetail is routed with a dovetail bit, no bearings, and the shaft of the bit runs along the jig acting like a guide or something. It's not as good as a bearing but there isn't enough space to allow for a bearing.
Typhoon Guitars
