It is currently Thu Apr 23, 2026 8:31 pm
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Chisel build thread
PostPosted: Wed Aug 01, 2012 7:53 pm
First name: Tony
Last Name: C
City: Brooklyn
I could watch you do this all day. Thanks for preserving an old world art and letting us watch you do it!
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Aug 02, 2012 6:31 am
Great stuff Phillip! Reminds me of a wonderfull PBS (I think) show chronicling the old world making of a samurai sword. Love these kinds of demonstrations.
Milton, ON
PostPosted: Thu Aug 02, 2012 9:04 am
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Thanks guys, I'm glad you're enjoying this.
Dennis, the purpose of the twisting is to manipulate the layers of steel to produce the desired pattern, it doesn't affect the performance. This is a variation of the basic twist pattern, where you twist a single bar. Another twist pattern I like is turkish twist. Here's an example of that pattern:
And here's a knife with the same pattern as the chisel will be:
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Thu Aug 02, 2012 9:10 am
First name: Phillip
Last Name: Patton
City: Yoder
Here's what I got done this morning. First, I ground the bar clean. When twisting a square bar, you make deep grooves, almost like screw threads. The bottoms of those grooves can get forged into the surface, and if you don't grind them out before final forging, you might be in trouble.
Then I started drawing out the tang:
Then the blade part is drawn out width-wise. I was shooting for a finished width of 3/4", so I want it a bit wider to allow for grinding:
Now the whole thing is thermal cycled a few times. This relieves stress and refines the grain.
Once that's cooled down, I'll start grinding.
Regards,
Phillip Patton
PostPosted: Thu Aug 02, 2012 10:19 am
First name: Tony
Last Name: C
City: Brooklyn
The knife with the twist pattern the same as the chisel will be is un-freakin-believable! I absolutely love it! I see one of those in my future. Gorgeous Phillip. Just gorgeous.
PMoMC
PostPosted: Thu Aug 02, 2012 10:45 am
First name: Patrick
Last Name: Hanna
State: Missouri
Phillip, I see you are making a tanged chisel this time. I've been wondering up to this point whether it would have a tang or a socket. If you have also made socket chisels, would you post a few pictures? I'd be very curious to know whether you would forge or lathe a socket. Many thanks for this excellent demonstration.
Patrick
PostPosted: Thu Aug 02, 2012 11:31 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Wow, this is very cool. Makes me wish I had a chance to win! laughing6-hehe
PostPosted: Fri Aug 03, 2012 7:14 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
just wanted to chip in and say that I'm really enjoying this thread too!
What a prize!
We are all in the gutter but some of us are looking at guitars.
PostPosted: Mon Aug 06, 2012 5:39 am
Every time I see stuff like this, I get the urge to build a forge.
Then I price everything out and realize I don't even have enough hours in the day to do half the things I've already got on my wish list, and figure I should just enjoy watching other talented individuals work.
PostPosted: Wed Aug 08, 2012 10:14 pm
If I don't win one how much to just buy one?
Old growth, shmold growth!
PostPosted: Wed Aug 08, 2012 11:56 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
+1, but when I don't win, how much to buy one?
PostPosted: Sun Aug 12, 2012 7:34 pm
First name: Phillip
Last Name: Patton
City: Yoder
Patrick
I haven't made any socket chisels yet. If I did, I'd probably try to forge it close to shape, and use a guide for grinding and filing the rest of the way.
About $175. :)
Thanks everybody else for your comments, and I'm glad to facilitate a walk down memory lane, Filippo. :)
Regards,
Phillip Patton
PostPosted: Sun Aug 12, 2012 7:40 pm
First name: Phillip
Last Name: Patton
City: Yoder
Ok, time to get working on the handle (actually, I made the handle a couple weeks ago, it's just easier for me talk in the present tense ;) ).
I'm making this handle out of scraps of knife handle wood I had laying around. Arizona desert ironwood and african blackwood.
First step is to clamp the pieces in the four jaw chuck on my lathe:
and drill all the way through one piece, and most of the way through the other:
I'm using a piece of bronze between the two pieces of wood to add contrast and to keep them lined up right:
Regards,
Phillip Patton
PostPosted: Sun Aug 12, 2012 7:43 pm
First name: Phillip
Last Name: Patton
City: Yoder
Now the pieces are all glued together (using CA):
then ground clean:
Then I hog off the material where the ferrule will be using the bandsaw:
Then chuck it up in the lathe again and turn it round:
Regards,
Phillip Patton
PostPosted: Sun Aug 12, 2012 7:46 pm
First name: Phillip
Last Name: Patton
City: Yoder
Now for the ferrule. I'm making it out of bronze also, and the only turning stock I had was 1.5" diameter. But, it was partly turned down to size from a previous project. [:Y:]
Now the ferrule is cut off, and glued to the handle blank:
And the handle starts to get shaped:
Regards,
Phillip Patton
PostPosted: Sun Aug 12, 2012 7:52 pm
First name: Phillip
Last Name: Patton
City: Yoder
Initially, I shaped it with a thumb stop:
but didn't like the way it felt, so I ground it off. The spacer in the handle is a different kind of bronze than the ferrule, and is very hard to machine, so all the shaping after the above pics, were done free hand on the belt grinder.
After rough shaping, it was sanded with slack belts through 600 grit, then buffed:
Tomorrow, I'm hoping I'll be able to heat treat the blade.
Regards,
Phillip Patton
PostPosted: Sun Aug 12, 2012 8:00 pm
First name: Jay
Last Name: Swann
City: Austin
Zip/Postal Code: 78739
It's so amazing to me to watch people with real talent. Were I to win the chisel, it would become one of my prized possessions. What a work of art!!!
PostPosted: Sun Aug 12, 2012 8:52 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
that is so cool!!!!! looks great!! [:Y:]
MK5acoustics.com
 Post subject: Chisel build thread
PostPosted: Sun Aug 12, 2012 9:58 pm
First name: Tony
Last Name: C
City: Brooklyn
So nice!
PMoMC
PostPosted: Sun Aug 12, 2012 10:36 pm
First name: Darryl
Last Name: Young
State: AR
I can't believe I just now seen this thread. Thanks so much for posting this step by step tutorial. I've enjoyed it very much!
PostPosted: Mon Aug 13, 2012 9:41 am
First name: Marcus
Last Name: Bailie
City: Kirkland
There needs to be a knife-making subform. I could look at pictures like this all day long.
...or I could just go find a knife makers forum. Bah, like I need another forum to go to.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Mon Aug 13, 2012 12:24 pm
First name: Big
Last Name: Jim
That is beautifull work Phillip . This is by far the best thread of the challenge LOL
PostPosted: Sun Aug 19, 2012 10:37 am
First name: Phillip
Last Name: Patton
City: Yoder
Well, I didn't get around to heat treating until Friday, because I wanted to get a bunch of knife blades ready to do at the same time, to conserve energy. So here's the chisel:
and here are the knives I did:
The gray coating you see is anti scale compound. It protects the surface from the effects of oxygen at high temps.
Here it is after quenching. The steels I used for the chisel are shallow hardening, so require a fast quenchant. Traditionally, this was done in the urine of a red headed virgin, but it's hard to find virgins nowadays, so I use a quench oil designed for fast steels. It's almost as fast as water, but without the risk of cracking, which would be very disgusting this far along...
After tempering, which is done twice at 350 degrees for a couple hours, it's back to the grinder to clean up the grinds, trying to make everything symmetrical and straight:
I finished up on the grinder with 240 grit, then went to 400 grit by hand:
Regards,
Phillip Patton
PostPosted: Sun Aug 19, 2012 10:46 am
First name: Phillip
Last Name: Patton
City: Yoder
Then into the etching tank. I etch in ferric chloride. I like a fairly weak solution, because I think it looks nicer to do many slow etches, with light sanding in between, than to do a couple deep etches.
I etch for 10 minutes, and here's how it looks:
Then sand with 600 grit, etch for 10 more minutes, then buff with a fairly hard wheel and green chrome compound:
Then etch for another 10 minutes, then it goes into the neutralizing bath, which is just water and baking soda.
Regards,
Phillip Patton
PostPosted: Sun Aug 19, 2012 10:48 am
First name: Big
Last Name: Jim
I think you might make more money by building custom guitar chisels for luthiers ! Amazing work Phillip . [:Y:]
