It is currently Fri Aug 15, 2025 9:20 am
 Post subject: Source for hollow forms.
PostPosted: Fri Sep 14, 2012 10:05 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
I searched but didn't find quite what I was looking for. Please excuse me if this has been answered (a million times)
Hollow forms seem to run from $60-$100. Any recommendations for a source for hollow forms? Does anyone make one that is a LOT better or a LOT cheaper than the others?
I seem to remember seeing one that was already glued down to another MDF board for added strength but now can't find the link.
Any advice would be much appreciated.
PostPosted: Fri Sep 14, 2012 10:56 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
http://www.cncguitarproducts.com/luthie ... ishes.html
PostPosted: Sat Sep 15, 2012 12:57 am
Hi Linus, I make the dishes on CNC and they are double laminated. In my opinion you can not make a stable dish out of a single piece of manufactured board (MDF or Plywood) because of the way board products are manufacture using pressure. Once you remove some material from only one face the board distorts. So I laminate prior to adding a radius. This ensures stability. My dishes are heavy so shipping is not cheap but the dishes, at $75 each, are! I can make ANY radius you like and there is no charge for custom radii unless I have to try and match an existing unknown radius.
PostPosted: Sat Sep 15, 2012 10:38 am
I agree with Shane. I don't use MDF either . The product may look like it but it isn't . MDF machines very nicely but is not stable for the reasons Shane stated . You get what you pay for.
PostPosted: Sat Sep 15, 2012 10:49 am
I just need to be clear, I do use MDF but it is laminated and in that process is very stable. The point I wanted to make is that any manufactured sheet stock (mdf, plywood, plexiglass, lexan, steel, and anything else) that is created in a process where pressure is used will distort if the face is machined. So it needs to "stabilized" or somehow "equalized" BEFORE that surface is machined. So that is why I laminate first and then apply two coats of varnish to all surfaces when I am finished. In this process these dishes are super stable, I have made hundreds of these over the past few years, shipped all over the world with no complaints for their stability.
Users browsing this forum: Bryan Bear, guitarjtb and 15 guests
