It is currently Mon Jun 23, 2025 12:29 pm
PostPosted: Sat Aug 04, 2012 11:35 pm
First name: Chad
Last Name: Gibson
City: McColl
State: SC
Zip/Postal Code: 29570
I'm building a pickup winder but I don't have the money to buy a good counter for it so I'm resorting to modding a calculator for this propose. Unfortunately every calculator I find has those flimsy plastic circuit boards that would melt when I solder the wires to the connections on the equals button. Does anyone know of a descent calculator I can buy or do I have to start rummaging through a second hand store to find one.
PostPosted: Sun Aug 05, 2012 12:42 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
You probably need a lower wattage iron. Like a 10 watt iron. What are you using?
Another day, another dollar.
PostPosted: Mon Aug 06, 2012 9:20 am
State: AR
Chad you probably noticed that you didn't have to soldier the wire
when you were locating the contact points so they could be glued
in place.
Another option-http://www.amazon.com/Digital-Photo-Laser-Tachometer-Contact/dp/B001N4QY66/ref=sr_1_1?ie=UTF8&qid=1344262344&sr=8-1&keywords=electronic+tach
The calculator for counter will probably lose accuracy around 600rpm's.
I'm not certain of the optical one function controls...and didn't see an "on" button and
no mention if one has to keep the reading control pressed but it may be a better
choice for accuracy.
Keep us posted on how it works out and good luck.
PostPosted: Mon Aug 06, 2012 3:21 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Here's some pics of my setup:
I got the calculator at Menards for $3.50. It has the "real" circuit board, so was easy to solder.
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Tue Aug 07, 2012 4:51 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
I used a computer mouse with wire soldered to the left click button. Open your laptop calculator function and use it as your counter. Works like a charm.
PostPosted: Wed Aug 08, 2012 12:48 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I saw a simple set up once, similar to the photos but with a single cog on the edge of the wheel. The cog would hit the = key on the calculator each revolution. Just enter "+1" and start the wheel. Each time the cog hit = it would keep adding 1. Pretty simple tech but it worked.
PostPosted: Thu Aug 09, 2012 3:17 pm
First name: Mark
Last Name: Sorrentino
I think the computer mouse sounds pretty solid. I'm getting ready to do this myself. Got an old sewing machine for $5. Have some magnets ready to go. All I need is some magnets to charge them with and to set up a counter.
PostPosted: Sat Aug 11, 2012 6:49 pm
State: AR
Darrin I thought your way was great so I gave it a shot. It worked at very low rpm's
but way to slow. Somewhere around 150 and it would stop. Is that the way yours is or is there something I could do to increase it?
I'm using a reed magnetic switch wired to the mouse.
PostPosted: Tue Sep 18, 2012 11:37 pm
"cub" counters are cheap on ebay. They can count very quickly. Reed switch will probably be your limiter. Try an optical sensor as a trigger. This is what I'm trying to use. Just arrived today. No instructions. No English on the board. http://www.amazon.com/Amico-Slotted-Opt ... cal+sensor
I think I'd rather use a reflective sensor, but for $5.99 it was worth trying.
Edit -- Maybe I don't know what I'm talking about. Lots of stuff online talks about how fast reed switches are, but I haven't found a spec yet.
Mike Lindstrom
PostPosted: Thu Sep 20, 2012 8:38 pm
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
No, I think you are right. Reed switches are limited by the mechanical latching of the magnetic mover to the contact. I have tried multiple switches in conjunction with both digital and analog mechanical counters, and accuracy fails well below what I would call a good winding run speed. When looking at the feedback on an O-scope, you just see a breakdown in the signal based on latching irregularities.
I would recommend hall effect circuits, or optical interrupts.
Stephen
www.ziegenfussguitars.com
PostPosted: Sat Sep 22, 2012 12:10 am
First name: Darrin
Last Name: Oilar
City: Cottonwood
I would skip the reed switch. I soldered two leads onto the left click on the mouse, one got grounded to the sewing machine, the other lead to a wire that is contacted by the foot on the sewing machine for each revolution. If you're not using a sewing machine, the principle is the same, you just have to create a circuit somehow. Seemed to be pretty accurate up to the speeds I would be comfortable winding.
First name: Darrin
Last Name: Oilar
City: Cottonwood
