It is currently Thu Aug 07, 2025 1:26 am
 Post subject: Binding Channnel Prep
PostPosted: Fri Nov 02, 2012 2:32 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
OK, now it is time to glue on my wood binding. I plan to use Titebond, as with most things on this build. But would Elmers white glue be a better choice?
And, should I do anything to the channel before gluing? I am wondering if it is worthwhile to seal it with shellac first.
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Fri Nov 02, 2012 2:39 pm
I wouldn't shellac it if you plan to use wood glue....
PostPosted: Fri Nov 02, 2012 2:54 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Titebond works great. No shellac. You want clean wood surfaces for glue up. Make sure your shop is at 40-45% RH, your binding is bent to shape as close as possible without kinks, several strips of binding tape ripped up and ready to go, and just go for it!
PostPosted: Fri Nov 02, 2012 3:16 pm
+1 for titebond orig. You remembered to knock off the inside corner of the binding, right?
Milton, ON
PostPosted: Fri Nov 02, 2012 3:52 pm
Ah, Dave beat me to it. Knock down (round out) that inner binding edge. Only use shellac if you're going the CA route.
Good luck!
PostPosted: Sat Nov 03, 2012 12:13 am
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
Yep, already took down the inside corner of the binding. I will do a bit of fine tuning tomorrow since Iv'e figured out how to bend the stuff. Can't wait to see how it turns out!
Phil
PostPosted: Sat Nov 03, 2012 4:44 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Have you done a dry fit yet?
Put the bindings on with no glue that is.
You may find some places that need to worked on.
Mike Collins
PostPosted: Sat Nov 03, 2012 11:39 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
Yep, did that this morning. One piece was. well, I found a piece of leftover broken binding long enough to remake that one. And another I was doing some fine tuning to, well it broke on me in another place. But I think i have it close enough to right (by checking dry fit) that I can glue it back together before I glue it in the channel. It was a clean break, and the curve was pretty much dead on when it snapped. Think that might work?
i figure the rest of the broken pieces I'll make a scarf joint and glue them together on the guitar.
Any other suggestions for the best way to handle multi-piece?
Phil
Users browsing this forum: No registered users and 41 guests
