It is currently Wed Aug 13, 2025 9:39 pm
 Post subject: Taylor Matte Finish
PostPosted: Tue Nov 06, 2012 9:00 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have a friend with an older Taylor, matte finish. Why did any of the makers go to this finish? Mostly I see it on mahogany bodies. Is it polyester? Is it considered valuable? Do folks ever refinish these?
 Post subject: Re: Taylor Matte Finish
PostPosted: Tue Nov 06, 2012 9:30 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Just a different look than the usual gloss. Probably cheaper than polishing. I dunno what Taylor uses...it varies by model year I think
I like a matte finish on some guitars, like this one... viewtopic.php?f=10101&t=38120
PostPosted: Tue Nov 06, 2012 10:00 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I've been told it's a conversion varnish. The gloss is a UV polyester.
Brian
PostPosted: Wed Nov 07, 2012 12:09 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Hmm. Conversion varnish. That makes sense. To remove it would be a mess. Toxic strippers.
And then, still no gaurentees.
PostPosted: Wed Nov 07, 2012 12:59 pm
First name: Tom
Last Name: Rein
City: Saline
Why do you want to remove it? Some folks have successfully buffed out Taylor's matte finishes if that is the look you're after.
Stay with the happy people.
--Reynolds Large
PostPosted: Wed Nov 07, 2012 1:23 pm
Last Name: Howard
City: Magnolia
State: Delaware
May not buff out clear if it has a flattener added. You can most likely spray nitro right over it, but there could still be the issue of a flattening agent.
Brian
PostPosted: Wed Nov 07, 2012 2:13 pm
I would be quite surprised if it was anything but the satin version of their regular finish.
Three base coats, sand level, satin coat...no buff, price comes down...
PostPosted: Wed Nov 07, 2012 3:44 pm
I wouldn't bother refinishing a mat finished Taylor. I'd trade it in for a glossy one. I don't think that the work involved would be worth the end result. Why spend a few hundred dollars refinishing a guitar when Taylor probably has a gloss version of the same guitar for the same or less money.
I don't like Taylor's satin finish. It look OK but it squeaks when it brushes against your arms and body. I find it really annoying.
PostPosted: Wed Nov 07, 2012 5:53 pm
Price goes down? Not according to any build to order sheets I've seen. I think if they finish the guitar on a sunny day there's an upcharge (Sorry, just annoyed at the cost of a BTO Taylor......)
:twisted:
PostPosted: Wed Nov 07, 2012 6:01 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Their regular finish is Polyester. UV cured. Only way to get it off is spend days sanding or a heat gun.
I agree the effort is high. Lets say he decides against doing that. The only other thing he wants is the pickguard removed and a pickup installed. Low heat from the gun to take the pick guard off?
