It is currently Wed Apr 29, 2026 3:54 am
PostPosted: Sat Nov 24, 2012 2:49 pm
First name: Joshua
Last Name: Abbott
City: Salt Lake City
State: UT
Zip/Postal Code: 84105
Hi everyone!
So I'm working on my Stew Mac OOO guitar kit and have decided that I want to redo the soundhole rosette to resemble the Martin OOO42 (http://static.musiciansfriend.com/deriv ... 4514_R.jpg)
The top has not been glued to the sides yet, but I have glued all of the soundboard bracing on so that leaves me with 3 questions:
1.) Is it too late to redo the soundhole rosette? Or is it a bad idea to mess with this since I have already glued all the bracing on?
2.) What is the best way to remove the glued rosette pieces.
3.) What is the best way to remove the epoxied abalone purfling (a modification I made.)
Any tips would be greatly appreciated!!
Thanks!
-- Josh
PostPosted: Mon Nov 26, 2012 7:37 pm
the rosette dimensions for a 42 are very different from what you have here and to cut them you need a rosette jig. with the sound hole cut out you will have a hard time to do it well. If you do insist on doing it 1st get the rosette jig, Then cut a sound hole filler and drop that into the top so you have a center point to locate from. l
PostPosted: Tue Nov 27, 2012 4:03 pm
I had pretty good luck cutting the rosette out on a guitar I was working on. I would use a rosette cutter (router with circle cutting jig) to cut a round disk that is the size of your sound hole. I put one layer of binding tape on the outside diameter of the cutout ("plug") and then carefully pressed the plug into the sound hole so it was flush with the top and snug. You could probably use a few layers of tape depending on how snug the plug is when mounted in the top. Once this was complete I used my rosette cutter to route out the existing rosette. Once everything is done you can remove the plug.
Good luck!
Brad
Avon, OH
