It is currently Tue Jul 22, 2025 2:41 am
PostPosted: Fri Nov 30, 2012 11:48 am
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
Has anyone used saple for neck wood construction? Is it stable enough for a classical guitar I want to build?
bBake.
Blake Dixon
Kelowna B.C.
PostPosted: Fri Nov 30, 2012 11:57 am
State: ON
Hi Blake,
I've used it on a number of steel strings, I have not had any issues with stability (all my necks are reinforced with carbon fiber). In general I have found that it can be heavier than Honduran. It is fairly easy to shape, but not as nice as Honduran. Also a lot of people prefer the look of Honduran which tends to be a nice golden brown under finish, over the Sapele which does not have the same richness in colour. Is there a reason you are considering Sapele as opposed to Honduran?
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Fri Nov 30, 2012 2:45 pm
Sapele will do just fine with regards to stability, although it will definitely be neck heavy. I found some low density africain mahogany (Khaya) is pretty good weight wise, and the best being spanish cedar. Plus it carves like a charme!
Alain Moisan
(Now building just for fun!)
PostPosted: Fri Nov 30, 2012 3:22 pm
First name: William
Last Name: Snyder
City: Brooklyn
For my classicals I like Sp cedar that's med density for the species (it can vary a lot and some of the really light stuff makes me a little nervous for necks so I'll usually use it for linings, etc. and some of the heavy stuff is just as heavy as med density H mahogany.) or H. mahogany that's medium-lower density for the species (although, I do have one rather large Honduran board in the shop right now that is extremely light that I won't use for necks).
All of the sapele I've handled is a little too heavy for my taste in classical necks. Don't get me wrong-it'll work, just not my preference.
PostPosted: Fri Nov 30, 2012 5:38 pm
First name: David
Last Name: Wren
State: ON
Zip/Postal Code: M4C 4X5
I agree ... the weight may very well be a problem with a nylon string.
PostPosted: Sat Dec 01, 2012 4:06 am
I've done a Classical with Sapele. It is heavier but not to the point that it causes a problem. If a player is holding the Guitar in the normal playing position then I don't see it as a problem at all. If you are really worried then simply counteract the weight with something heavy at the tail block. There's enough players using a Smallman and their type, which are seriously heavy Guitars.
PostPosted: Sat Dec 01, 2012 7:15 am
Country: Romania
The sapele I have is darker and heavier than mahogany, not to be confused with khaya which is usually light, stringy, and often with much tension within. I am using khaya for solid linings and after cutting the strips almost always bend one way or the other, and often in different directions.
On the sapele a rosewood fingerboard or matching it with a high density body wood should erase any neck weight issues.
My favorite cedar is the heavy, mahogany like one, even if it is scarce. It carves better and I feel more confident about making a slim neck with it. On medium density cedar i will insert a rosewood or ebony spine and the extra light one is turned into linings and braces.
Build log
