It is currently Wed Jul 30, 2025 2:14 pm
PostPosted: Fri Nov 30, 2012 8:22 pm
Well, I've searched the web and this site and am coming up short. Looking for membrane material, probably silicone but am open to suggestions. Needs to be flexible enough not to crush fairly thin braces.
Thanks.
http://www.chassonguitars.com
PostPosted: Fri Nov 30, 2012 8:37 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Hey Kent, you may want to check Sylvan Wells' page. I'm not sure if he has a link, but I know he does a lot of vacuum stuff.
PostPosted: Fri Nov 30, 2012 8:57 pm
First name: Rusty
http://www.veneersupplies.com/products/ ... erial.html
Polyurethane material for making a bag or frame press. 54" x 36" size, $26.50 from Joe Woodworker/veneer supplies.
In a pinch you can use heavy gauge clear vinyl from a fabric store(avoid sharp corners).
Polyurethane is far superior to vinyl, not as clear, but clear enough.
Lots of info on the joewoodworker site.
PostPosted: Sat Dec 01, 2012 1:23 am
Kent, check out Torr Technologies in Auburn, WA. All kinds of good stuff!
www.torrtech.com
PostPosted: Sat Dec 01, 2012 8:55 am
First name: Dean
City: Orient
State: Ohio
Zip/Postal Code: 43146
Kent:
LMI carries vacuum membrane.
Dean
PostPosted: Sat Dec 01, 2012 12:13 pm
Thanks all. Rusty, I've used vinyl before and it's not flexible enough for what I'm doing. Is the polyurethane as flexible as they say?
PostPosted: Sat Dec 01, 2012 1:09 pm
Vinyl is available in various thicknesses, also. Perhaps a thinner sheet would offer enough flexibility?
PostPosted: Sun Dec 02, 2012 3:27 pm
Last Name: Garrish
The stuff LMII sells, and which most use for this application, is neoprene rubber. You can get it in 1/32" and even 1/64" thicknesses, though the 1/32" is plenty flexible and I'd worry about tearing the 1/64" stuff after repeated use. They've got a pretty high markup on it VS an industrial supplier.
If you want silicone, the cheapest supplier I've found (and I've looked!) is Amazon Supply. It tends to be a lot more expensive than the neoprene, but you can get it in clear and it might be more durable long term.
Bob Garrish
PostPosted: Sun Dec 02, 2012 3:28 pm
Last Name: Garrish
If you need to 'get 'er done' then garbage bags work fine and come in thicknesses that are quite flexible at a good price :)
(Done this more than once or twice for vacuum bagging stuff)
Bob Garrish
PostPosted: Tue Dec 04, 2012 6:42 am
First name: Rusty
Kent,
The polyurethane that joe woodworker sells is very flexible, plus it comes in two thicknesses.
Check out their video, they put a baseball under their poly.
Users browsing this forum: CarlD, Chris Pile and 7 guests
