It is currently Sat Aug 02, 2025 10:55 pm
 Post subject: Walnut?
PostPosted: Mon Dec 03, 2012 12:10 pm
City: Quakertown
State: Pa
I am gearing up to start a scratch build out of Black Walnut and was curious whether or not it would be wise if I constructed the guitar with Walnut Neck and heel blocks. I know that it is accetable to use it for a neck but haven't heard it mentioned for neck or heel blocks. Anyone with experience?
 Post subject: Re: Walnut?
PostPosted: Mon Dec 03, 2012 12:40 pm
Last Name: Ensor
City: Springfield
State: Missouri
I don't see why you couldn't use walnut for your blocks. The biggest things you want to consider is the grain direction (with the sides) and the weight. I say go for it.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Mon Dec 03, 2012 1:15 pm
Walnut makes good necks too.
PostPosted: Mon Dec 03, 2012 2:10 pm
First name: Aaron
Last Name: Craig
State: Missouri
It will work fine for blocks and makes nice necks.
Aaron Craig
PostPosted: Mon Dec 03, 2012 2:21 pm
Last Name: Kincheloe
The ghost of C.F. Martin will rise up fro the floor and tell you that mahogany is cheap and plentiful, and therefore you shouldn't bother using anything else. Then put all your guitars slightly out of tune, and return to his slumber.
Other than that, it works about as well as anything.
PostPosted: Mon Dec 03, 2012 2:36 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I have used it for blocks, and it works great.
PostPosted: Mon Dec 03, 2012 4:45 pm
I use Walnut for blocks and necks and like it alot. It's a plus for me because i have tons of it. :D
PostPosted: Mon Dec 03, 2012 8:58 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Just finishing one with black walnut sides, back, neck and tail blocks, kerfed linings, and neck. It's a little heavier than mahogany, but otherwise is fine.
http://www.casperguitar.com
PostPosted: Mon Dec 03, 2012 10:03 pm
City: Quakertown
State: Pa
Great! [:Y:] Thanks All! Just what I wanted to hear.
I will probably laminate a few pieces for the Neck block ( I know, it will add some weight), but it I were to use a solid piece, I would hanker a guess that rift sawn would be better than quarter?
Scott
PostPosted: Mon Dec 03, 2012 10:19 pm
First name: Tim
Last Name: Allen
City: San Francisco
Here's one with walnut back, sides, and neck. Also used a walnut bridge, stained black.
I've made two necks from walnut. While it goes a little slower than Honduras mahogany I found it a pleasure to carve.
Tim Allen
"Never hurry, never rest."
PostPosted: Tue Dec 04, 2012 2:48 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
laughing6-hehe Love it!
Pablo Picasso
PostPosted: Tue Dec 04, 2012 5:27 pm
Last Name: Arnold
City: Newport
Rift sawn would be ideal, but most of the blocks I have used were QS, with no problems.
I don't think laminating will add much weight, unless some of the laminations are some other denser wood.
PostPosted: Tue Dec 04, 2012 10:37 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
Well I just made a guitar with a black walnut back, sides, AND top. and it sounds marvelous. But I've never made a neck with it before; it's something I plan to do tho.
