It is currently Fri Aug 08, 2025 10:59 am
PostPosted: Thu Dec 06, 2012 11:17 am
First name: Cecil
Last Name: Carroll
City: West Plains
State: Missouri
Zip/Postal Code: 65775
I have a Martin D35 with a bowed neck. It has the tube neck reinforcement.
I plan to heat the fingerboard the allow the glue to release slightly and clamp it to hold the new position until the glue resets.
Now, two questions: Is this the right approach? Do I want to shot for flat or do I want a slight back bow?
Since this is my first attempt at this kind of repair, any other tip will be welcome.
cecil
PostPosted: Thu Dec 06, 2012 11:45 am
NO NO NO
This is designed to be compression fretted. Heating really won't work with this. What you do is use a tang that pushes on the fret slot. That springs the neck. You need a set of compression fret wire with tang widths from .0185 to .0245. The thinned wire may be used over the extension. Then start with the 24.5 at fret 10 - 6 -4 and see if the neck moves. You want to see a slight back bow start from about the 7th fret to the nut of .006 to .009 , if nothing happens as the heaviest from 8 7 and see what you have then use .0205 and .0225 or .0195 and watch the neck.
I will tend to go on the square tube to .090 and then string up for a week to let the barbs set , then I level sand the frets with the head stock supported and 10lb on the body , this will get you close. I had an article in Guitarmaker a few issues back about compression fretting.
PostPosted: Thu Dec 06, 2012 2:19 pm
First name: Cecil
Last Name: Carroll
City: West Plains
State: Missouri
Thanks John, once again you've saved my bacon. I don"t recall ever seeing a source for compression fret wire. Could you direct me to a supplier?
Thanks, once again for the rescue,
cecil
cron
