It is currently Mon Apr 27, 2026 7:52 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Thu Dec 06, 2012 9:51 am
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
Goodin wrote:
Just curious, what is the typical top and back radius, if any, for a uke??
Typically, backs are 15' and tops are 25' but many are built with flat tops and backs. Koaloha, which makes koa sound cannons, builds flat but their structural system is unique. Other than Koaloha, flat is generally (no flames for the generalization, as there are certainly other exceptions) not a good sign in ukes.
PostPosted: Sat Dec 08, 2012 4:31 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Come Join Us at Ukulele Underground Forums. Go to the luthiers forum. It's all there an them some. Many of the top builders frequent that forum.
http://goatrockukulele.com
PostPosted: Sat Dec 08, 2012 10:09 am
First name: Jim
Last Name: Kirby
Thanks for the pointer. A whole new forum to explore [:Y:]
Jim Kirby
kirby@udel.edu
PostPosted: Sat Dec 08, 2012 11:53 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I was wondering about ukes too, last Soprano I built didn't turn out so well because I overestimated the size of stuff. I am working on a Tenor based on the Stewmac kit, but its a low priority project as of now because it's not a paid commission. I will probably get back to it next week if time permits.
Typhoon Guitars
PostPosted: Sun Dec 09, 2012 9:40 am
If you can make your uke sound like a "bouncing flea" then I think you got it right! [:Y:]
PostPosted: Mon Dec 10, 2012 4:44 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
Definitely!
Coincidentally I came across two eBay listings which I think show clearly the difference between a scaled-down guitar and a uke as I like 'em - just comparing the two should be informative.
http://www.ebay.co.uk/itm/Hand-Made-Soprano-Ukulele-by-Jacob-Menear-of-JKM-Guitars-/181040697097?pt=UK_Musical_Instruments_Sting_Instruments&hash=item2a26ddcf09
http://www.ebay.com/itm/Vintage-Style-1-C-F-Martin-Mahogany-Ukulele-w-Original-Case-/110973938248?pt=LH_DefaultDomain_0&hash=item19d68fea48
However good the first one sounds, it could clearly sound a whole lot better if not muffled by that enormous bridge and fretboard. And head-heavy or what?
PostPosted: Mon Dec 10, 2012 4:57 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
profchris wrote:
However good the first one sounds, it could clearly sound a whole lot better if not muffled by that enormous bridge and fretboard. . .
I'm glad I read this quote. Extending the FB over the top to the soundhole (like a guitar) is what I had planned to do in my head. I don't even think I bothered to recognize that many ukes don't do this. On a guitar (as I understand it) the upper bout area of the top is not as active acoustically as the rest of the top. I hadn't even considered that this would be different on an uke. It does make sense that being very different in materials and construction, this is something I should not over look. Aesthetically, I would prefer to have the FB extend to or nearly to the soundhole. Perhaps I could float it over the top.?. Input appreciated. . .
Bryan Bear PMoMC
PostPosted: Mon Dec 10, 2012 5:48 pm
City: winnipeg
State: manitoba
Country: canada
I am completely at odds with Profchris. I use a five inch long bridge and limit my fretboard to fifteen frets. I am not impressed by the "ricky-ticky" sound of many ukuleles and the sound can be manipulated using wood and depth of box.
Tone quality is quite subjective.
Bob :ugeek:
PostPosted: Tue Dec 11, 2012 2:33 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Country: UK
Bob :ugeek:
Are you building sopranos or a larger size, Bob? Once you get up to tenor, and maybe even to concert, the nano-scale problems start to go away. But a 5 inch bridge on a 6.5 inch wide (or less) soprano body strikes me as likely to kill it stone dead - unless you've built one and know how to make it work.
Ricky-ticky is a great word for the sound of an over-built soprano, which an awful lot are. A good one (probably that Martin I linked to) sounds radically different.
On your last point I'm with you all the way, and I too am playing with wood and depth of box (and top shape) to explore different sounds. But still, at soprano size I find that unless you go super-light it's always ricky-ticky.
PostPosted: Fri Dec 14, 2012 12:40 am
City: winnipeg
State: manitoba
Country: canada
Profchris:
I usually build tenor or baritone. Concert is marginal for my big, clunky, fingers.
This year I built a monster baritone with 22" scale (too big for me) and it sounded like a four-string guitar.
I built two maple-spruce tenors. One with one inch depth and the other with 2 3/4" depth. The shallow one really barks while the regular one is rounder. I still prefer my mahogany, it is really mellow. All three are built identical, sort of.
I am taking the regular maple-spruce to Hawaii this year and it is probably not coming home.
Bob :ugeek:
Users browsing this forum: No registered users and 249 guests
