It is currently Sat Apr 18, 2026 11:29 pm
PostPosted: Tue Jan 22, 2013 11:03 am
I finished the neck on my latest classical..offered up the tuners and they are wider than the headstock top to bottom.
Seems they are all pretty much the same dimensions now I look.. duh
Anyone know of any slimline tuners or think of a go round that doesnt involve scraping off the finish and doing a backstrip
TIA
PostPosted: Tue Jan 22, 2013 1:39 pm
First name: David
Last Name: LaPlante
These are the narrowest that I know of at 15.5mm.
http://www.stewmac.com/shop/Tuners/Clas ... lates.html
PostPosted: Tue Jan 22, 2013 6:32 pm
Schaller made some classical tuners that could be used with or without the base plate - MK Mini's. They are closed back tuners so are a little modern looking.
You could also file down the plates on Stewmac's restoration tuners and make bushings to increase the post diameter. That might be more work than redoing the finish.
How much width do you have to work with?
PostPosted: Tue Jan 22, 2013 9:04 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
You've got a few suggestions, but to me the easiest one is to add a backstrip and redo the
finish, IF it is an easily repaired finish like French polish or Nitro, where witness lines are
not a problem.
Gene
PostPosted: Wed Jan 23, 2013 8:21 am
Thanks for the suggestions
I thnk the Sloanes are a bit out of budget for this guitar which is a
Falcate bracing, crossover type classical so I will go with the MK minis which will actually be fine on this particular guitar.
Ahhhhh no refinishing [:Y:]
