It is currently Fri Aug 22, 2025 7:26 pm
 Post subject: Wavy Walnut
PostPosted: Tue Feb 05, 2013 12:03 pm
First name: Larry
Last Name: Hawes
I'm bending some black walnut over a hot iron and got some short choppy 'waves' in the bend. Used quite a bit of water and wondered if that could cause it?
Thank You and Best To All
 Post subject: Re: Wavy Walnut
PostPosted: Tue Feb 05, 2013 1:06 pm
First name: Tony
Last Name: C
City: Brooklyn
You might be going to fast. Walnut bends pretty easily so you should not get those waves. Are you rocking the wood and heating more than just the small area on the iron?
http://www.CostaGuitars.com
PMoMC
PostPosted: Tue Feb 05, 2013 1:15 pm
Are you talking about across the side? If so, it is usually due to slab or mixed grain. Less water would help but probably won't eliminate it.
If it's flamed walnut and the waves are along the bend, you're probably just getting some faceting where the grain changes direction. Not much to do about that but less water is pretty much always better.
http://www.chassonguitars.com
PostPosted: Tue Feb 05, 2013 1:20 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Could be too much water, or not enough heat for the amount of water you used.
Any water should be gone by the time you finish bending, at least with walnut.
It's been a while since I bent walnut, but IIRC, just a spritz of water was enough.
PostPosted: Tue Feb 05, 2013 5:23 pm
First name: Larry
Last Name: Hawes
I think the flame is causing the issue Kent and faceting is probably the best term for what I'm seeing.. I'll try a little less water.
BTW I'm bending at .083" - .088", can I go thinner?
PostPosted: Tue Feb 05, 2013 5:24 pm
First name: Larry
Last Name: Hawes
Actually have begun to do more of the 'rocking' Tony and it's helping, thanks for the tip.
PostPosted: Tue Feb 05, 2013 5:59 pm
I wouldn't go thinner than .080" partly because the faceting needs to be sanded out. Less water and maybe a spring-steel backer on the tight sections should help.
If you are getting end grain lifting or fracturing then a little more heat or a little slower bending may help too.
PostPosted: Tue Feb 05, 2013 7:59 pm
First name: Larry
Last Name: Hawes
Thanks very much for the advice Kent
