It is currently Fri Aug 15, 2025 2:51 am
PostPosted: Mon Feb 11, 2013 6:03 pm
First name: Jonathan
Last Name: razo
City: dallas
State: tx
I have a client that is bringing in a guitar because it has some sort of "gunk" foggy area, that accumulated from the use of his Ergoplay stand. He has a nitro finish on the guitar, and wants to see what can be done to remove it from the guitar, he tried naphtha, but to no success. I was wondering what might have caused this and what a viable solution would be?
thanks
Jonathan
 Post subject: removing
PostPosted: Mon Feb 11, 2013 6:05 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Nitro does not get along with a lot of plastics/vinyl. It softens the finish and really can cause a mess. Never leave a nitro finished guitar on a stand with plastic/vinyl always have cloth between.
This is not the first time I've heard of those suction cups leaving marks in nitro. Once you fix it I would suggest that the owner does not leave it attached. Instead just put it on and take it off when they are done.
Here is a link to a similar circumstance on the AGF
http://www.acousticguitarforum.com/forums/archive/index.php/t-270720.html
PostPosted: Mon Feb 11, 2013 6:28 pm
Usually lemon oil or naptha will take most gooey stuff off nitro.
Warm, soapy water sometimes works, and I even used some Fast Orange once.
If you are very careful.... you could try acetone, but you have to use very light pressure, not leaving the applicator (rag, or whatever) on the surface but a few seconds. Use as a last resort.
PostPosted: Mon Feb 11, 2013 6:30 pm
If only the surface of the finish has been affected you may be able to lightly sand and rebuff that area
PostPosted: Mon Feb 11, 2013 8:00 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
If it is the type of reaction I have seen from some stands with foam rubber it has likely gone deep into the finish. Sand and buff may work, most likely will need a spot refinish.
Brian
PostPosted: Tue Feb 12, 2013 11:57 am
Last Name: razo
City: dallas
State: tx
Thanks everyone for the help! I will try wet sanding and buffing it, because seems like nothing else worked!
Users browsing this forum: Colin North and 14 guests
