It is currently Fri Apr 17, 2026 2:33 pm
 Post subject: Resonator build
PostPosted: Wed Jan 23, 2013 3:51 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
Getting jigged up for my up coming and first resonator build....Cone finally shipped from Beard, backordered for a month, and not having a circle cutter to use I put this together this afternoon...works good...based off one I saw somewhere online..
1/4 inch mdf, 1/4inch draw bolt hardware ,home depot, and rigid trimmer...works good..will post pics as I proceed... I do this as a hobby so it could take some time Eat Drink Eat Drink
MK5acoustics.com
 Post subject: Re: Resonator build
PostPosted: Wed Jan 23, 2013 4:28 pm
I will be watching with great interest.
What are you using for plans / design?
PostPosted: Wed Jan 23, 2013 9:04 pm
Last Name: Tracz
Me too!
_Mike
_Mike Tracz
MCT Guitars
https://www.instagram.com/mustcreatethings/
https://www.youtube.com/mustcreatethings
PostPosted: Wed Jan 23, 2013 11:46 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
It will be based on my MK5 design...which is a 12 fret cutaway .. Bubinga back and sides , with a "a" Sitka top...beard spider bridge and cone, along with a gold cover , sound ports and tailpiece all well made in south korea!!!!...a Resoacoustic!! wow7-eyes any suggestions , ideas along the way will be appreciated...haven't decided yet about the top although I would like to use a radiused top if possible to help with the neck angle... idunno
MK5acoustics.com
PostPosted: Sat Jan 26, 2013 7:52 pm
I would certainly consider checking into the designs of Tim Scheerhorn. His internal construction is fairly unique, and is what I based my design on.
PostPosted: Sat Jan 26, 2013 9:52 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
I was thinking on something along the lines of a brace with arms that connects to the neck block , heel and sides, and radiused , the sides will have solid linings to link to .... idunno subject to change!!!!!!!!!! wow7-eyes
MK5acoustics.com
PostPosted: Sat Jan 26, 2013 11:27 pm
First name: Britt
Last Name: Askew
Looking forward to seeing this Eat Drink
PostPosted: Sun Jan 27, 2013 8:54 pm
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
I don't see how a radiused top would work, as you need a flat top for the coverplate.
I sanded an angle into the upper bout to get my neck angle. I have a National El Trovador and it looks like National does the same. If I lay a straight edge across the top. the lower bout is flat, but the upper bout angles down, dropping off about 1/8" at the neck block.
Kent
PostPosted: Tue Jan 29, 2013 9:40 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
If I lay the coverplate down on a radiused top it fits flush.., but what about recessing the plate into the top???? which would require recessing the cone slightly more.... I do see a possible break angle issue using a tail piece??? idunno doesn't seem to be a lot of information out there???
what about the thought of possibly using a pinless bridge instead of a tailpiece to compensate for the different break angle??????
beehive
MK5acoustics.com
PostPosted: Tue Jan 29, 2013 10:55 am
The cover will conform to a 30' radius without any issues but the floor of the well needs to be flat. There's really no reason to arch the top, most builders just put a small wedge under the FB when they set the neck.
As to recessing the cover I've done them both ways and sitting flat on the top isn't really a big deal. Looks fine either way.
As to the tailpiece/break angle I think you're over-worrying this a bit. The break angle doesn't have to be very high.
PostPosted: Tue Jan 29, 2013 2:34 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Another jig to radius main brace using my radius dish...I will rout everything out after gluing to the top piece which is some really stiff Sitka,,,thinned to .115
MK5acoustics.com
PostPosted: Sun Feb 03, 2013 6:10 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Made some more progress
MK5acoustics.com
PostPosted: Sun Feb 03, 2013 6:12 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
the stick used in the neck block glue up is for alignment only....
MK5acoustics.com
PostPosted: Sun Feb 10, 2013 1:42 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Fitting the top....gluing UTB on a 70 foot caul to flatten fretboard area
sanding in radius to the rims..
MK5acoustics.com
PostPosted: Mon Feb 11, 2013 8:40 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Still winging it...having fun!!!!! wow7-eyes
Top is radiused to the standard 28 foot radius, the area under the fretboard extension has a 70 foot radiused brace to flatten the upper bout.
cover plate is recessed 3/64 into the top with the cone recessed another 1/4 inch which put the top of the spider flush with the lower part of the opening in the coverplate...all this gets my neck angle in the ball park... :shock:
My circle cutter has worked flawlessly so far!!!!!!!!!!! bliss
MK5acoustics.com
PostPosted: Wed Feb 13, 2013 6:00 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
More progress!!! about to close the box then start on the neck, still toying with the idea of a wooden pinless bridge instead of the tail piece..
MK5acoustics.com
PostPosted: Mon Feb 18, 2013 8:31 am
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Just stumbled across this. Very cool build. Looking good so far. What is the purpose of the dowels connecting the top and back?
PostPosted: Mon Feb 18, 2013 8:37 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
support for the front of the cone brace and a place to attach a baffle If desired..This is my first Reso build so I am borrowing some design ideas from other reso builds pizza
MK5acoustics.com
PostPosted: Wed Feb 20, 2013 5:49 pm
First name: Jeff
Last Name: Smith
Looking great Wes!
 Post subject: Neck build
PostPosted: Mon Feb 25, 2013 7:36 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
some progress on the neck build and setting the angle...
MK5acoustics.com
PostPosted: Mon Feb 25, 2013 7:39 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
sanding angle
MK5acoustics.com
PostPosted: Mon Feb 25, 2013 7:43 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
cutting the tenon , Cumpiano style
MK5acoustics.com
PostPosted: Mon Feb 25, 2013 7:46 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
drilling tenon
MK5acoustics.com
PostPosted: Mon Feb 25, 2013 7:50 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
flossing heel for flush fit setting centerline..so far so good on the radiused top and the neck angle !!! bliss
MK5acoustics.com
PostPosted: Tue Feb 26, 2013 5:21 pm
Very nice build!
