It is currently Sat Jul 26, 2025 8:26 am
 Post subject: Thinning Bone Blanks
PostPosted: Thu Feb 21, 2013 9:29 pm
First name: Darryl
Last Name: Young
State: AR
I have oversized nut and saddle blanks that need thinned. What is the best way to thin and keep a consistent thickness? I can sand by hand but I have to keep pressure just right to prevent a wedge shape.
 Post subject: Re: Thinning Bone Blanks
PostPosted: Thu Feb 21, 2013 9:33 pm
I run them through my thickness sander
PostPosted: Thu Feb 21, 2013 9:42 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
John, does it take a fixture to run them through your thickness sander?
thanks, Mike
PostPosted: Thu Feb 21, 2013 10:03 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
If its really oversized, like turning a 3/16" saddle into a 1/8" or even 3/32" saddle, then I use a bandsaw to get it close then sand it... I do not have a thickness sander so all I can really do is stick it to a piece of wood and sand it on the belt sander... having power makes it easier to not sand it into a curve. I suppose you can also use the Wagner Safe T Planer too.
Typhoon Guitars
PostPosted: Thu Feb 21, 2013 10:12 pm
I just take a scrap piece of wood the thickness of the bone blank, cut a channel the same as the height of the blank, cut the channel (rectangle shape) longer than the blank so the wood gets sanded first.
Now run this with the blank in the channel through the sander. The board will ensure the bone blank doesn't get thrown back from the drum or tilt up...
This makes it easy to check in the nut or saddle slot on the go.
Here's a picture. It literally took me less time to make this versus writing the above.
PostPosted: Thu Feb 21, 2013 10:18 pm
First name: Darryl
Last Name: Young
State: AR
I wondered if I could use my drum sander. I'll give it a try.
What is the thickest saddle you've used successfully, 5/32"? Wanting a little extra compensation adjustment.
PostPosted: Thu Feb 21, 2013 10:46 pm
First name: Darryl
Last Name: Young
State: AR
Good idea Rod!
PostPosted: Thu Feb 21, 2013 10:49 pm
Darryl Young wrote:
...What is the thickest saddle you've used successfully, 5/32"? Wanting a little extra compensation adjustment.
3/16" works for me. Plenty of room for compensation and still plenty of bearing surface so you don't get grooves in the saddle or break strings.
http://www.chassonguitars.com
PostPosted: Thu Feb 21, 2013 10:55 pm
Last Name: coloccia
Country: States
I've done this when I've needed a Fender blank and all I had were 1/4" blanks.
Flatten one side of your blank. Take it over to the disc sander, flat side down, and square one edge of your blank so it's nice and orthogonal to the side you flattened. Now you have a flat side and a square up edge...this edge will be the edge that goes down in the nut slot.
Put the flattened side of the blank face down, and put the UNFLATTENED edge up against a 1/8" piece of wood (or however thick you need) and scribe a line. Take a small piece of wood that is nice and square, and double sided tape the blank to the wood. Tape it so the edge you flattened is DOWN towards the table, and the side you flattened is taped to the wood. I just put the piece of wood down on my bandsaw table, place the nut down on the table, and push them into each other so everything's nice and flat and flush. Then take it over to your disc sander and sand until you split your pencil line. You'll find that it's trivially easy to do this on your disc sander once you have the piece of wood to hold onto and the pencil line to monitor your progress. It should take about 10 seconds....20 if you're being all careful and persnickety.
PostPosted: Thu Feb 21, 2013 11:34 pm
First name: Danny
Last Name: Vincent
Where's that "Like" button when you need it. Thanks Rod!
PostPosted: Fri Feb 22, 2013 6:16 am
First name: Tom
Last Name: West
State: Nova Scotia
Darryl : I have used over .200,but most are around 3/16".
Tom
PostPosted: Fri Feb 22, 2013 6:44 am
Rod and I use the same method
PostPosted: Fri Feb 22, 2013 10:05 am
First name: Darryl
Last Name: Young
State: AR
Have you guys used a 3/16" saddle on a non-belly bridge (like a pyramid) that is 1" from front to back? Do you still have plenty of room for the bridge pins? If this worked ok, were you using a 90 deg saddle or did you have it slanted back 5-7 degs?
Maybe I should ask this a different way.....and then I could figure things out myself. What is the minimum amount of material that should be left between an opening (sadddle pocket, bridge pin hole, etc.) and the edge of the saddle? Also how much material should be left between the saddle pocket and the bridge pin hole? If I knew this information, I could easily figure out what would and what would not work on a bridge tha tis 1" deep front to back.
PostPosted: Fri Feb 22, 2013 10:10 am
First name: Darryl
Last Name: Young
State: AR
Double post sorry.
PostPosted: Fri Feb 22, 2013 10:48 am
First name: Tom
Last Name: West
State: Nova Scotia
Darryl: Just checked a guitar I have sitting by the computer. Bridge 1.125" wide with 3/16" saddle and there is plenty of room at least for me. Perhaps if you draw it out you may feel more at home.
Tom
PostPosted: Fri Feb 22, 2013 11:49 am
First name: Darryl
Last Name: Young
State: AR
Thanks Tom. 90 deg saddle or is the saddle slanted rearward? Not sure I can get 1 1/8" out of the blanks I have.......might be 1".
PostPosted: Fri Feb 22, 2013 12:17 pm
First name: Tom
Last Name: West
State: Nova Scotia
Darryl: Sloped slot......conventional,not sure in terms of degrees. Also the pin holes follow the slope of the saddle. I have 1/4" behind the bass E so I could remove 1/8" and be at 1" even. I would make sure you have decent meat in front of the saddle............whats behind pins not as important.At least in my opinion.
Tom
PostPosted: Fri Feb 22, 2013 12:40 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I just thin them on a flat surface with sandpaper. Flip it every 10 strokes or so to keep it even and measure often with calipers. Watch out though....those edges will get quite sharp. I hate cleaning blood stains off bone
PostPosted: Sat Mar 16, 2013 3:46 pm
regarding the thickest saddle i've used sucessfully it was about 5/16" or so. but this was in the repair side, not a build.
the guitar was an epiphone which had one of those execrable gibson style adjustable saddles and a bolt on neck a la fender with the action in the stratoshere. needless to say not a great guitar.
the owner was client of my then significant other and wanted the thing made playable, but as she was not flush with money and was taking lessons, the budget for the job was tight.
neck angle adjustment via a shim brought the action down, but the saddle adjustment screw posts where eating holes into the top. pitched the adjustable saddle mechanism and replaced the whole thing with a corian saddle. lots of room to adjust intonation which was needed since the bridge was too close to the nut.
the oversized saddle drove the heavily braced plywood top sufficiently that her instrucor thought she had a new guitar when he heard her warming up.
i have seen photos of builders using up to 1/4" or so but haven't heard the results.
Users browsing this forum: Colin North, DennisK and 9 guests
