It is currently Sun Jul 27, 2025 10:43 pm
 Post subject: synthetic finish
PostPosted: Sat Feb 23, 2013 4:39 pm
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Zip/Postal Code: 411044
Country: india
Hello friends
till today on my 5 guitars i have dont shellac polishing
but as im not trained very well i dont get good finishing on my guitar
so this time i want to apply synthetic finish
should i go for PU or Laquer?
do i have to fill the pores?? if yes can i use pumice for it?
also do i have apply any coat before pu or lacquer?
can i french polish the guitar with 2-3 sessions before i go for synthetic finish?
waiting for ur reply....
thnks in advance
[:Y:]
 Post subject: Re: synthetic finish
PostPosted: Mon Feb 25, 2013 2:19 pm
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Country: india
why no reply this time???
PostPosted: Mon Feb 25, 2013 4:11 pm
Rahoul, I think because it's hard to know where to start!
French polishing is an art & a skill ....lots of instructional info here & elsewhere (eg http://www.milburnguitars.com/fpbannerframes.html ) so learn & practice.
PU means nothing to me, but you can pore fill under lacquer with Zpoxy or equivalent, a generic pore filler or shellac pumice.
Which finish you "go for" is a question every builder asks ... no easy answers here! Depends on your skills, tools& equipment, availability etc etc etc etc
Hope this helps at least a bit.
Milton, ON
PostPosted: Mon Feb 25, 2013 4:14 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
It's a tough question to answer from here. Do you have any spray equipment? What products in particular are you looking to use? Poly or lacquer leaves the field wide open, that's almost anything that is not a varnish. Do you need to pore fill? NO, but should you? I don't know. Can you use shellac as a sealer or base? Yes, sometimes. Do you need a sealer at all? Depends on the finish.
Brian
PostPosted: Mon Feb 25, 2013 4:25 pm
First name: David
Last Name: Morris
City: McKinney
Finishing seems like something you ought to be able to just do, right? Like how you'd grab a paintbrush and go at your interior walls. But there's a ton to know about it, and a huge learning curve. There are some great books on the subject - Bob Flexner's being the standard. And that's just understanding finishes. Executing proper technique is another thing altogether.
David Morris
