It is currently Mon Aug 04, 2025 3:27 pm
 Post subject: body woods for classical
PostPosted: Mon Feb 25, 2013 5:31 pm
First name: Ronald
Last Name: Lenz
City: Caroline
State: Alberta
Zip/Postal Code: T0M 0M0
Does anyone have any experience in using bubinga for classicals? I'm in the early stages of learning this craft and I'm especially interested in the differences of tone related to wood choice. I happen to have some nice bubinga in my shop but I don't want to build a guitar just to practice my gluing - I would like the chance to end up with a good sounding instrument. I recently completed my second classical in cedar and mahogany (because I already had the stock). I would consider the tone to be "subdued". Am I right in generalizing that a harder, denser body wood produces a brighter tone? Any input greatly appreciated.
PostPosted: Mon Feb 25, 2013 5:36 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Have a look at this paper by Trevor Gore. Very useful reading about wood selection.
http://asadl.org/poma/resource/1/pmarcw ... ypassSSO=1
Pablo Picasso
PostPosted: Mon Feb 25, 2013 5:44 pm
Bubinga is a very good choice for a Classical. Density and hardness approximates to that of Indian rosewood. As a wood for Back/Sides it isn't used very much. That's more to do with it being relatively cheap. Use it with confidence. Someone on another forum stated that Hauser thinks it is only second to Brazilian Rosewood.
PostPosted: Mon Feb 25, 2013 7:50 pm
First name: Jim
Last Name: Kirby
I'm building an elevated fingerboard guitar following Mick Lazar's approach, which has a Bubinga body. I got my Bubinga in a binge at the local Woodcraft about 5 or 6 years ago, when they brought in a stack of good-sized QS planks, some with decent figure and some plain. I have about 10 sets sawn and enough wood around to do another 6 or so. I think it should work out well. (I have a bunch of Padauk obtained the same way.)
Jim Kirby
kirby@udel.edu
PostPosted: Mon Feb 25, 2013 8:02 pm
I have used it for a classical guitar. It was fine. My take is that it is a bit less appealing than Indian Rosewood, sound wise. Somewhat thinner sound vs fat sound, if that makes sense. However the difference was slight, and could have been caused by other issues. Hard wood to work though. Tough on tools. It was my 3rd guitar. Shane's Lutz top.
PostPosted: Tue Feb 26, 2013 12:10 pm
Do you have any more info about this?
Help me with my bad english, please. Does this mean, Mr Hauser thinks:
- Bubinga is as good as BRW, or
- Bubinga is not as good, only 2nd choice?
I don`t get it...
cheers, alex
upppps..thats a little bit big...
Last edited by Herr Dalbergia on Tue Feb 26, 2013 12:16 pm, edited 1 time in total.
PostPosted: Tue Feb 26, 2013 12:15 pm
First name: Ronald
Last Name: Lenz
City: Caroline
State: Alberta
Waddy, when you say tough to work, can you offer me any advice on bending. Soak it, bend dry, steam? I really liked the rosette on your guitar with the double R motif - it would suit my long time business name (Raven River Timber Works) . Care to share where you got it?
PostPosted: Tue Feb 26, 2013 1:21 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I built 2 guitars out of Bubinga, and I love the way it looks compared to Indian rosewood. It's got a lot more character cosmetically, sonically I can't comment, but it is a bit harder to sand, plane, and scrape because it seems to be a harder wood overall. It also has a more interlocked grain making bending harder but having bent Padauk, Indian rosewood, and Bubinga, I can't say it's any harder as long as you exercise proper precaution and thin it properly. If you're put off by its relatively light color, it will look splendid under a red stain. I plan on (if I have extra money available) buying some more padauk and Asian bubinga locally when I get the chance... a lot cheaper than LMI but I have to resaw it myself.
Typhoon Guitars
PostPosted: Tue Feb 26, 2013 2:27 pm
I don`t get it...
cheers, alex
I take it as meaning that Brazilian Rosewood is his first choice and Bubinga would be his second, Bubinga being ahead of any other Back/side tonewood out there apart from Brazilian Rosewood.
I can't remember where I read this but it's probably from one of the Luthiers on Delcamp. I've only ever used Bubinga once and it seemed perfectly good to my ears. . . but using it once is far too soon to make any sort of judgements especially where there are so many other variables. Just going by it's density and hardness I can't see a problem.
PostPosted: Tue Feb 26, 2013 2:55 pm
First name: Jim
Last Name: Kirby
My sides for the ongoing build bent with no problem at all (I use a Fox style bender). Just a light spritz with water, bent at about the same temperature as EIR. I don't remember any special problems with it.
Jim Kirby
kirby@udel.edu
PostPosted: Tue Feb 26, 2013 2:59 pm
The Tile is an artistic license WRT with a pair of opposing R's. I make them, and I'd like to keep it as my signature rosette tile, but I don't have it registered, so I probably wouldn't sue you if you copied it. Too expensive!
PostPosted: Tue Feb 26, 2013 3:02 pm
I bent mine on a pipe, and had some problems. Every place there is figure, it wants to crack. Probably not a problem with support, but if I was going to bend a figured piece, I'd use SuperSoft 2 before bending.
PostPosted: Tue Feb 26, 2013 3:59 pm
First name: Ringo
At first I thought it was one of the space invaders from the old video game ;)
PostPosted: Tue Feb 26, 2013 6:07 pm
Space invaders could make a cool rosette!
PostPosted: Tue Feb 26, 2013 8:27 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
My apologies for being slightly off topic, but I have admired Waddy's rosette tile ever since I first visited this site. I recognize it as the "Waddy Thompson" signature for a classical guitar. I even admire (envy) it more now, since I'm trying to work up a tile of my own; buying a pre-made rosette was so much easier.
PostPosted: Tue Feb 26, 2013 10:49 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
With my limited experience, bubinga is an absolute b*tch to plane. Sanding is fine. I built a cradle for my brother's first child, and the end panels were bubinga. After getting incredible tear out (with a well-tuned L-N plane), I took it to the local cabinet shop to be sanded. Smartest move I ever made.
PostPosted: Tue Feb 26, 2013 10:52 pm
Yeah, but it dulls sandpaper fast too. Or it did in my case. I'd be sanding and realize that all of a sudden I wasn't doing anything except rubbing it.
PostPosted: Wed Feb 27, 2013 12:31 am
First name: David
Last Name: Morris
City: McKinney
I don't even try a plane on Bubinga anymore. It just rips up the wood more often than not. It may dull sandpaper, but I don't know a better way to work it.
David Morris
PostPosted: Wed Feb 27, 2013 12:55 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
That may be why they are not commonly used compared to indian rosewood.
Typhoon Guitars
PostPosted: Wed Feb 27, 2013 10:40 am
First name: Ronald
Last Name: Lenz
City: Caroline
State: Alberta
Back to Waddy's beautiful tile - since it is your signature piece, obviously I wouldn't think of using it. Thanks for all the info
