It is currently Sat Apr 18, 2026 3:20 am
Post new topic Reply to topic  [ 92 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Jan 27, 2013 10:17 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Awesome work Doug!!! What are the lamination layers in your neck? I really like the look. You are underway now, it won't be long till you have the box closed up.
PostPosted: Sun Jan 27, 2013 10:24 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Thanks Zeke. Lamination is simply maple and walnut. I don't want a lot of fancy binding on this beast. I am hoping the visual appeal will be in the contrasting colours of maple/sitka along with walnut binding and headstock and ebony fingerboard and bridge. The soundhole will also be lined with a ring of thin walnut.
Here is a pic of the type of look I am going for and it comes from this website with some really cool, artistic guitars:
http://guitarrascustom.blogspot.ca/2011/05/5-string-acoustic-bass-italian-spruce.html
Doug
PostPosted: Thu Jan 31, 2013 6:14 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
dbalzer wrote:
Neck lamination...I neglected to ensure it is straight side to side when clamping and now there is a curve of 1/16". Tempted to leave it as it will never be really noticeable once the fingerboard is on. Tempted also to redo it. I'll let is sit for a while and see how I feel later on. I'm learning that sometimes the best thing to do in lutherie is to walk away from the project and get back into a zen place.
So I've decided to redo the neck. I'm considering this to be a normal luthier experience. Get it right. Minimize that which you compromise. It's only time and wood. Move on and get over it. I'll NEVER regret correcting minor mistakes that only I would have noticed. I'll always regret not fixing things that I will always think of when I look at the finished product for years to come. I should note that it took me a few days to arrive at this...also normal in the life of the luthier I presume.
Doug
PostPosted: Fri Feb 01, 2013 2:25 pm
Last Name: Miranda
I'm totally stealing your radius dish-making idea!! That's awesome. I LOVE that kind of ingenuity.
Awesome build, BTW.
PostPosted: Sat Feb 23, 2013 11:30 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Notice the string anchors near tail block to accommodate classical bass strings.
Thinning the 0.065" walnut centre strip prior to glue up.
Doug
PostPosted: Sun Feb 24, 2013 1:59 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Prepping the 0.1" walnut sound hole binding ... Drying after bending on iron.
Not shown: 1/8" Baltic birch ply patch surrounding sound hole.
Doug
PostPosted: Sun Feb 24, 2013 9:03 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So up until now I have not managed but only measured the RH in my shop. The RH in the shop has ranged from 25% - 45%. Now that I have my top and back plates thinned to size I can so easily see the rapid impact humidity has on my tonewood. So prior to further assembly such as bracing, closing the box, etc., I am now the proud owner of a humidifier for the shop.
I am going to aim for 40%. My region in western Canada is naturally quite dry.
Doug
PostPosted: Sat Mar 02, 2013 10:59 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Humidity is now stable and so is the wood. Here are some progress pics. I can't tell you how much fun all of this is!
You will notice the top bracing is highly unconventional. This is largely due to the strings terminating near the tail block and therefore eliminating much stress at the floating bridge.
Doug
PostPosted: Sat Mar 09, 2013 11:36 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
End flash done. Time to put the top on.
Doug
PostPosted: Sun Mar 10, 2013 11:50 am
First name: Zeke
Last Name: McKee
You are moving right along. I got some catching up to do!
PostPosted: Sun Mar 10, 2013 5:32 pm
First name: nick
Last Name: dingle
Looking good, mate.
PostPosted: Sun Mar 10, 2013 10:33 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So I was not totally pleased with that first end flash as it was slightly out of balance. The biggest thing I am learning in this new challenge is to step back and think before committing myself to a course of action. The first attempt on the maple inlay, I attempted to hold the inlay manually while I scribed around it but it moved and I didn't really notice until later on. On this attempt I first of all chose a piece of maple that continues the grain through from rib to rib. I also glued it down in place with liquid hide glue before scribing. After scribing I heated up the inlay to release it...worked much better and, obviously, held its desired position.
This is my second such "do-over." Definitely won't be my last. Neck #1 is coming in handy as a test cut object prior to running Neck #2 through a machine. Don't burn mistakes too quickly!
Doug
PostPosted: Tue Mar 12, 2013 9:18 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Doug
PostPosted: Tue Mar 12, 2013 9:20 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Glued the soundboard on. I suspect it is quite normal for the builder to begin to "pretend play" the guitar at this point?
Doug
PostPosted: Tue Mar 12, 2013 9:44 pm
First name: nick
Last Name: dingle
Yup.....
At least on the first few ;)
PostPosted: Sat Mar 16, 2013 8:19 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Productive day today: fingerboard cut, side dots, truss rod installed, string anchor cover plates inlayed, bridge rough shaped, headstock shaped with Claro walnut book matched veneer. The back plate is not on yet on as I am waiting for a pick up that is on order. It is installed under the bridge (not saddle) and I think it will be much easier to install prior to attaching the backplate. Unlike a standard guitar the soundhole on this oversized beast is a long ways from the bridge.
Doug
PostPosted: Sun Mar 17, 2013 3:21 am
First name: nick
Last Name: dingle
Sadly, Doug, you have neglected to put in a belly cut and an armrest. I am deeply disappointed.... laughing6-hehe
Just kidding. Looks great. I wnat ot know all about this one, as it's coming up on my list soon, soon, my pretty--- wow7-eyes not you Doug, the bass build.......
PostPosted: Sun Mar 17, 2013 7:24 am
State: Tennessee
What a beast, looking good, I'm interested in hearing this one with the classical strings.
PostPosted: Sun Mar 17, 2013 9:14 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I'm really looking forward to stringing it up as well. Obviously the hope is that it sounds much more like an upright bass than a steel string acoustic bass. Imagine my disappoint if it truly disappoints.... To win the challenge I could always "dub" in a maestro playing a double upright ;)
Doug
PostPosted: Tue Mar 19, 2013 6:36 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Uh oh. Attn: fretless bass players! See the YouTube video here that contains a serious warning against pursuing the fretless bass. Am I making a mistake? ;)
http://youtu.be/qJ0jE7_r3dg
Doug
PostPosted: Tue Mar 19, 2013 6:41 pm
First name: Zeke
Last Name: McKee
Hilarious Doug! I will be sharing that with my bass playing friends.
PostPosted: Wed Mar 20, 2013 4:29 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Aargh!!! So I have had to make two necks, two headstock veneers and now, out of necessity, my second bridge. The journey continues. This is known as the learning curve. All I can say regarding cutting saddle slots is...use a straight bit, not a up-cutting spiral bit. DUH!
Doug
PostPosted: Wed Mar 20, 2013 6:09 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Since we are making fun, a bass player told me this one at a bluegrass jam:
While a band was on stage, the guitarist was thinking, "Gee, I think that cute girl on the front row likes me." The drummer was thinking, "Gee, I hope we make enough money to get my van fixed." The bass player was thinking, "Gee..... G... G... G..." laughing6-hehe
Looking good, Doug. Keep it up!
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Wed Mar 20, 2013 10:15 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Very good Casey. When I play bass I don't think at all....known as the "chronic bass player staring into space" thing.
Doug
PostPosted: Thu Mar 21, 2013 3:53 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Lol, sounds like cellist's have the same problem as bass players!
https://www.youtube.com/watch?v=JdxkVQy7QLM
https://www.youtube.com/watch?v=LV5_xj_yuhs
laughing6-hehe
Pablo Picasso
