It is currently Fri Jul 25, 2025 8:55 pm
PostPosted: Sat Mar 16, 2013 3:45 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
In the past, i drilled two different diameter holes for these, the 25/64" on the back of the peghead and about 8mm on the front. Is this necessary? Can I just drill through at 25/64"? Or is it better to snug fit the locking screw?
PostPosted: Sat Mar 16, 2013 4:20 pm
First name: Tom
Last Name: West
State: Nova Scotia
Mike: Have never used Grover closed tuners but have used Shallers and Gotoh. For closed backs I don't drill a stepped hole but the extra support would not hurt in my opinion.
Tom
PostPosted: Sat Mar 16, 2013 6:05 pm
Keep step drilling, you want support for both the body of the tuner and the bushing.
PostPosted: Sat Mar 16, 2013 7:12 pm
+1 for Jeff and Tom
PostPosted: Sat Mar 16, 2013 8:18 pm
Yup, step drilling is the way to go. It prevents finish delam around the top holes if the grommets loosen up.
PostPosted: Sun Mar 17, 2013 12:11 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Hmmm. Ok. Makes sense. The way I step drill is to use a small pilot hole all the way through. Then that centers up the steps. Sound good? I was more concerned about torquing of the peg which could hurt tuning.
PostPosted: Sun Mar 17, 2013 7:51 am
FWIW, I have always drilled through with a 10mm bit and never had an issue. I guess drilling an 8mm hole for the top portion makes sense, I'm not sure it is required.
Alain Moisan
(Now building just for fun!)
