It is currently Fri Aug 15, 2025 1:13 am
 Post subject: Red spruce top
PostPosted: Sat Mar 16, 2013 3:38 pm
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
Is Red Spruce worth the extra cost when building a dread for bluegrass. It seems that a decent top is appx. twice the cost of Lutz or Sitka. Thanx, Vic.
 Post subject: Re: Red spruce top
PostPosted: Sat Mar 16, 2013 4:27 pm
First name: Tom
Last Name: West
State: Nova Scotia
Vic: All three can make very good dreads,but it is hard to top the Red Spruce.The Red may not come up to the standard of looks as the Lutz and Sitka. Stand by for other opinions and others spruces.......!!
Tom
PostPosted: Sat Mar 16, 2013 5:46 pm
Kinda, sorta, maybe, it depends. Personally, I have six nice Adi tops from the good people at Old Standard, but haven't had a chance to use any yet, so I can't give you first hand impressions.
The best info I have is from John Greven, who says, today's Adi is not like the first growth that Martin etc. used. It has great headroom but gets muddy. If you want a sound like the old
Martin dreads, the best choice is Lutz. Shane at high Mountain can fix you up with some nice tops. And he's a real nice guy to deal with, even if it's hard to get a hold of him at times.
Brent
PostPosted: Sat Mar 16, 2013 7:23 pm
Well this is anecdotal but I just completed #53, my first dred with a BZ body and Red spruce top. The wood was sent to me by the client and was a master grade top from Old Standard and the BZ was a very old straight grained dark set that was really something to behold. He said he got it from Robert Ruck years ago.
Have I become a believer? Hell yes! Was I nervous working with such valuable wood? Absolutely! Will I use the same combo again? You bet!
PostPosted: Sat Mar 16, 2013 7:35 pm
put me down as a believer in Red tops
PostPosted: Sun Mar 17, 2013 12:40 am
John, do you use Red Spruce for your bracing as well ? I thought I heard something about Martin using Sitka bracing on Red Spruce tops.
Any info on this would be appreciated.
Brent
PostPosted: Mon Mar 18, 2013 9:09 pm
Thousands of prewar dreads can't be wrong...
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Tue Mar 19, 2013 7:51 am
Ken, I had always assumed that the pre-war guitars were red spruce tops and bracing. A few months ago, I read somewhere that
many had sitka bracing. It was someone who has done a lot of repair work, possibly Greven(?) I thought John Hall would know,
or maybe Todd could jump in here.
Brent
PostPosted: Tue Mar 19, 2013 9:23 pm
Or Mario.
PostPosted: Thu Mar 21, 2013 2:45 pm
First name: Darryl
Last Name: Young
State: AR
I also read that Sitka spruce was used for brace material in old Martin's because it was cheaper. Can't say it's correct, just what I read.
PostPosted: Thu Mar 21, 2013 3:38 pm
Martin used the sitka for braces . There are a few rare examples but 99% are sitka. Modern times Martin has done Red braces as an upgrade.
PostPosted: Thu Mar 21, 2013 3:59 pm
First name: Tom
Last Name: West
State: Nova Scotia
I have a suspicion that in the 30's lots of Sitka was widely used for aircraft and was in sizes and grades easily cut up for bracing material. Top material,because it was not as widely use was procured as close to home as possible. The use of Sitka bracing just carried on in the shift to Sitka tops until the new Red Spruce trend. That would be my take on the Sitka bracing.
Tom
PostPosted: Mon Mar 25, 2013 8:37 am
First name: Corky
Last Name: Long
City: Mount Kisco
Lots of valid comments here from my own perspective. What hasn't been stated yet is that there's a lot of variation between samples of any given species of spruce. In other words, a given Sitka top could be stiffer and lighter than a given Adi top. So you really need to have an idea of what you're looking for in terms of stiffness to weight ratio, and measure the tops. One way is to measure the density of a top, in weight per volume (I use grams per cubic inch). Experts on this forum have implied that density is a pretty good proxy for stiffness to weight ratio (assumuing quartersawn tops) Other folks use deflection testing as a means to test stiffness.
Every top is different. And, as was stated earlier, prices on tops have a lot to do with how they appear.
