It is currently Thu Jul 31, 2025 6:09 pm
PostPosted: Sun Mar 17, 2013 3:46 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
What can I glue to the back of the inlay pieces to make it thicker to work with? I am using piano key covering and it's only at most 1/16 of a inch thick and brittle. Any Ideas. [uncle]
PostPosted: Sun Mar 17, 2013 4:24 pm
Last Name: Kincheloe
I usually just use wood veneer if I have a thin piece of shell or whatever that I want to match with some thicker pieces, although it can splinter off while sawing so there might be something better. But 1/16" is a pretty typical thickness for shell inlay, and ought to be fine for ivory as well. Just use very fine toothed saw blades. If it's brittle due to being full of micro-fractures, you could flood it with thin CA first.
PostPosted: Sun Mar 17, 2013 4:45 pm
That thin, multi-ply birch like they sell in hobby stores works well. http://www.hobbylinc.com/Hobby_and_Craft_Plywood
http://www.chassonguitars.com
PostPosted: Sun Mar 17, 2013 4:56 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
+1 for model plywood from hobby stores. I use 1/16th inch thick stuff a lot for exactly this purpose.
DF
Cambrian Guitars
PostPosted: Sun Mar 17, 2013 5:06 pm
First name: Kent
City: New Carlisle
State: Ohio
Thank you for your help. I will try the ply.
PostPosted: Sun Mar 17, 2013 11:51 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
You want to glue it to something white if you want to retain a white color in the ivory.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Mon Mar 18, 2013 4:30 pm
First name: Kent
City: New Carlisle
State: Ohio
What could I use that is white?
PostPosted: Mon Mar 18, 2013 4:41 pm
Bone.
PostPosted: Tue Mar 19, 2013 7:45 am
Holly veneer.
PostPosted: Tue Mar 19, 2013 7:59 am
You can also paint the inlay cavity white if you use the ivory at its present thickness. Gluing ivory to ivory with super glue also works well.
