Hi Everyone,
just like to say thanks to everyone that responded to my question - it is very much appreciated! One of the great things about being a member of a forum like this is how willing people are to offer their knowledge and experience to help someone with a problem. Awesome!
As someone pointed out (Jeff!), I cross posted this question to other forums and from all the replies it seems that this is common problem with the 16-32's and 22-44's. The most expedient solution seems to be to use a sled and the weight of a 3/4" ply or MDF sled should flatten the conveyor belt at the join line and give a better result.
The only downside I can see to a sled (especially for sides) would be that the use of infeed/outfeed tables would probably be mandatory. I do have these tables but rarely attach them to the sander because of storage/mobility issues.
I have heard of people using poly belts to fix this issue for the 22-44 but they seem hard to source (but are available from Klingspor for the 16-32). Anyone interested in exploring this option might like to read this post from the North Carolina Woodworkers forum for sources(
http://www.ncwoodworker.net/forums/showthread.php?t=47013).
My other question(s) is this - I have tensioned my conveyor belt as per Jet manual (enough tension so the belt doesn't slip when you place moderate hand pressure on the infeed side of the conveyor). Are other people tensioning as per the manual or can you put on a little more tension to help "flatten" the bulge around the join line on the conveyor? Any tips from anyone about how to achieve "correct" belt tension? I'm wary of overtensioning and bending my rollers but there seems to be scant info available in the manual about correct tensioning.
Thanks & Regards,
Steve.
