It is currently Wed Aug 20, 2025 10:28 am
PostPosted: Fri Mar 22, 2013 5:09 pm
Last Name: Sollod
What length neck blank do you need for a neck (25.4" scale length) with a stacked heel? I haven't tried a stack heel yet... Oh, and does cherry make a good neck?
www.swiftcreekguitars.com
PostPosted: Fri Mar 22, 2013 6:39 pm
State: Tennessee
12 or 14 fret? My 14 fret Martin style headstock is 21"-1/16
Cherry should make as good a neck as the wood you put into it:) Great wood = great neck, crappy wood, not so great duh
PostPosted: Fri Mar 22, 2013 7:51 pm
First name: Jim
Last Name: Kirby
For my classicals, I like the 36" blanks from Hibdon - that does the headstock and the full heel stack no problem.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Mar 23, 2013 8:20 am
First name: Tom
Last Name: West
State: Nova Scotia
Another alternative to a stacked heel is a solid block glued to neck blank. Easier to blend so that it gives the appearance of a one piece.
Tom
PostPosted: Sat Mar 23, 2013 8:22 am
Would that not depend on the thickness? (to get the depth at the heel)
PostPosted: Sat Mar 23, 2013 11:13 am
First name: George
City: Seattle
I'm in the middle of this process right now. A 35" x 3" x 7/8" blank worked for me, with room to spare.
I've never used cherry myself, but many people do.
George :-)
PostPosted: Sat Mar 23, 2013 11:51 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
If the wood is 3/4" thick or more & your guitar is not excessively deep, 12" is normally enough. A little planning to be sure you don't waste too much material is necessary. (A Spanish heel will take a lot more than 12".)
For a stacked heel to look good, there are a couple of things to keep in mind. The pieces need to be glued together in the correct orientation, or some pieces will look darker than others.
Using a sharpie, I draw a line down the centre of the face edge & mark several arrow points along the line. Once you cut the pieces, you need to arrange the lines & arrows so they are all pointing the same way when they are stacked together.
If the heel pieces & neck are cut from the same piece of wood, be sure to continue the line & arrows into the neck portion of the board to minimize any colour shift there.
The other thing that can spoil the appearance of a stacked heel is a very thin section under the heel cap. Try to thickness the wood before you cut it up, so you get roughly equal thickness on the last piece.
With a bit of care, a stacked heel can look (almost) like a solid piece of wood.
Hope this helps...
