It is currently Wed Aug 20, 2025 11:30 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 23, 2013 10:02 am
My last major kerfuffle was on a Wenge OM. I wiped the guitar down with a bit of DA and let it sit for about 1/2 hour. I started laying down coats of EM6000 and noticed a spotty haze or blushing under the finish. The conclusion of the forum was that I hadn't let the DA evaporate long enough. Only option.. Take it all off and start over..
oops_sign
PostPosted: Sat Mar 23, 2013 10:44 am
First name: Stuart
Last Name: Gort
My last mistake was to assume photography is easy.
I tapped a truss rod into the groove for a nice tight fit...which stressed the bottom and cracked the back of the neck long after it was finished. I think I can sand down to raw wood and CA the crack. Or possibly use the cnc to route out the area and replace it with a plug. The fit would be fairly undetectable but..the color would probably give it away.
StuMusic
PostPosted: Sat Mar 23, 2013 10:54 am
Good article. I had read it some time ago. Was worth re-reading
Worth showing again - probably my first serious double take: truss rod too deep, rod end not quite in the right place. neck too shallow. Yes, I fixed it - added wood to bottom of slot, used a shallower truss rod, put on new fret board.
PostPosted: Sat Mar 23, 2013 1:13 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
Just finishing up my very first build. Once I set it up the action was much too low. Had to take the neck off, removed the fretboard so I could have easy access to correcting the neck angle. Touched up the top were the fretboard had been glued down. Now touching up the finish along the neck where I removed the fretboard. Hopefully THIS time it will be done correctly. Otherwise I'll start a thread on triple takes...
PostPosted: Sat Mar 23, 2013 4:28 pm
The Thoughts about learner's impatience by William Cumpiano made me smile as I've worked with many people who William describes in detail :)
They want instant recognition, top money and an easy life without wanting to work, learn, make mistakes and grow as a person I call it the X-Factor generation - instant fame with all the trappings and no sacrifice on their part! idunno
I did a 4 year apprenticeship which taught me the basics; this was just the start of my learning experience and something that carries on today. I also worked with many talented people who were humble and shared the same principles that you are always a learner and you learn most from your mistakes. I have yet to meet the man who knows it all - but there again a few have said that they are that man! laughing6-hehe
To be someone must be a wonderful thing!
PostPosted: Sat Mar 23, 2013 6:01 pm
I just now had a chance to read the Cumpiano article. Nice!! A must-read for every member of this(and all other) luthier forum.
In case you didn't read it, here it
http://www.cumpiano.com/Home/Articles/A ... edagog.htm:
PostPosted: Sat Mar 23, 2013 6:44 pm
Rod True wrote:
Filippo Morelli wrote:
James Orr wrote:
Rod, I'm thinking about re-bracing that top we were discussing recently. It's pretty thin (.095"), and I'm just a little freaked that I don't have enough meat in the X.
I wouldn't. If a stiff top, 0.095" is not bad. Let it live and see what happens. You might be pleasantly surprised.
Filippo
I agree here James. Mind you this isn't a guitar for yourself is it......the worst that can happen is you have to do what probably all of us have had to do....re-top it.
Thanks for the company folks!!! Alain that's just a small sound port through the neck isn't it.....??
Thanks, guys. Logically, you're correct. I'm just squeamish about it. It feels good in my hands, and I'm usually around .1. This is my first time going this thin.
PostPosted: Sat Mar 23, 2013 7:05 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Josh H wrote:
callyrox wrote:
Thankyou so much for this post. It is so reassuring to know that you experienced builders sometimes go through the same thing that we beginners do. I'm getting ready to rout off the binding and re-bind due to gaps. I tried thinking of all the solutions to fix it without redoing, but it really just needs to be redone. I've been avoiding it now for a month. It's time to get back in there and just do it. Wendy
Every experienced builder was once a beginner. And one doesn't get to be experienced in this business without making a lot of mistakes. This thread reminds me of a great article from Cumpiano http://www.cumpiano.com/Home/Articles/Articles/pedagog.htm Anyone who hasn't read this should.
Josh
I remember reading this years ago - this quote stood out:
"A master is someone who has made more mistakes than you, has made mistakes you haven’t made yet, and has learned how to embrace them--thus learning to see them coming before they happen. So you go towards mastery one mistake at a time. How many mistakes can you stand? As many as it takes to be a master. The master has persevered past the errors until he's made all of them."
PostPosted: Sat Mar 23, 2013 8:06 pm
First name: Larry
Last Name: Hawes
What a great thread. Brings me back to earth as I sand through the finish again and again and start the too thin it cracked back again and remember that my new slot head design has to be thin enough for the tuners to reach the other side of the slot and that the 12th fret is actually 12 frets from the nut and did I build a caul for the fret board and why did the neck angle change after I finished the neck and over and over...sigh. Humbling really doesn't describe it.
Thank You and Best To All
PostPosted: Sat Mar 23, 2013 10:46 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
Ken Jones wrote:
Spyder wrote:
Let's see, still working on my first two. So far I have had to start over on:
Backs - made two that cracked
back braces - 2 sets each
rosettes - 2 each before scrapping them both
tops - new for each, with new rosettes
bindings - 2 each, top and back
Fingerboards - so far 1 each, but still trying to get the slots in the right place, so I may end up having to start over on those too.
Ain't this fun?
This is exactly why I don't recommend doing two right out of the gate...
I hear you! But every time I start something new, there are different steps where I think "Next time, I'm going to do it this way and see if it works better." So I decided to make two at once, so I could actually try out those different techniques while they were fresh on my mind, so hopefully I wouldn't forget by the time the next one came around.
Don't know if that was a good thing or not, but I can say I'll have quite an education on making these by the time they're done. For example, I now have experience making backs and sides out of two different woods, same for necks. I got lots of practice making wood bindings, also out of different woods. This experience alone taught me a lot about how different woods behave and that differrent techniques are required to make the bends.
So who knows, was it worth it to do two at once? having to redo so much was trying at times, but I'm hoping that number 3 goes much more smoothly because of all I went through on these.
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Sat Mar 23, 2013 11:30 pm
My take on it is that trying to build two at once, as your first, only assures that you'll make twice as many mistakes/flubs.
It also puts you in the wrong mindset, because you'll relax and think("well, if I don't nail it with this one, at least I'll get the next one done right"). I'd rather see you stressed-out, BUT get it right on the first go, because you couldn't afford to fail.
I've taught a few on-line courses and coached a good many, privately, and without fail, all those who insist that they can build two at a time, always one with "good wood" and another with "cheap wood" fail miserably. That's because they try to learn on the "cheap wood" piece, and because they don't expect to actually use the piece, they don't try hard enough. But after they fail with the cheap wood, they then try it with then good wood, but fail again. The reason? They didn't commit to doing it right on the first try, so they've actually conditioned themselves to ---never--- doing it right.
PostPosted: Sun Mar 24, 2013 2:45 am
One of my more memorable ones was not planning out the layout of carbon rods in a neck well enough, and carving right into them. Cursed, threw the neck away....and a week later repeated the same mistake with a second neck. Lets just say I don't splay the CF rods quit so far any more...
These users thanked the author Mattia Valente for the post: dbbrantley (Thu Oct 19, 2017 3:19 am)
Users browsing this forum: DennisK and 24 guests
