It is currently Fri Aug 22, 2025 3:43 am
PostPosted: Sat Mar 23, 2013 5:21 pm
First name: David
Last Name: LaPlante
Gentlemen,
What amount of compensation do you allow in determining the bridge position for an electric guitar, given a fairly low action and typical light or extra light guage strings?
I'm using a 25.5" Fender scale.
Also, given an adjustable bridge, how how far back would you set the default high E position (as well as the other string saddles) to allow a certain amount of reduction of compensation once everything's together and you're fine tuning??
Out of my normal element here.......
Thanks!!
PostPosted: Sat Mar 23, 2013 5:37 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Hi David.
Figure a rough compensation,
then make sure the bridge saddles have enough travel to accommodate that.
You,ve got a lot of latitude there.
PostPosted: Sun Mar 24, 2013 10:54 am
First name: Freeman
Last Name: Keller
The StewMac fretboard calculator will also give you the position of the bridge for proper compensation. It is interesting to me that different bridges have slightly different locations
http://www.stewmac.com/freeinfo/Frettin ... tcalc.html
When I built my Lester the value given by the SM calculator was a hair different than on the plans but I used it anyway and the saddles had enough travel to correctly compensate each string (ToM bridge)
PostPosted: Sun Mar 24, 2013 11:44 am
what bridge are you using. I try and set it up with the adjustable bridge points near the front so that 80% is behind and 20 in front. That allows getting the strings all intonated .
PostPosted: Sun Mar 24, 2013 1:03 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Hello David;
I start with the high e setback at 2mm
2.5 got the b
3mm for the g if a plain string is used.
D-2mm
A-2.5mm
E-3mm.
I'll let ya know when I hear from Maria !!
Mike Collins
