It is currently Mon Sep 15, 2025 12:09 am
PostPosted: Tue Mar 26, 2013 4:22 pm
First name: Larry
Last Name: Hawes
Or to actual size? Does it vary with large and small guitars? If smaller by how much?
Thank You and Best To All
PostPosted: Tue Mar 26, 2013 4:36 pm
Last Name: A
Build your form smaller - smaller by the thickness of your side plus blanket and slats if you are using them.
In my case I build my form approximately 1/8" smaller than the desired shape of my side.
PostPosted: Tue Mar 26, 2013 5:09 pm
i go smaller as well plus taper the ends inboard about 3 deg or so for spring back. i also pull the waist in tighter with a slightly smaller radius -again to deal with spring back. when all is bent up things pretty much relax to near net shape with very little tweaking needed. i also have some adjustable setting forms as well to place the sides into after they come off the bender.
PostPosted: Tue Mar 26, 2013 8:03 pm
I do mine the same size as the template and haven't had any problems, even with OM and smaller sizes.
Old growth, shmold growth!
PostPosted: Tue Mar 26, 2013 8:42 pm
First name: Ringo
I draw the outline of 1/2 the body on some plywood, then I draw another line about 1/8" inside of that. At the bandsaw I cut out the space in between the lines. Finally I clean up the curves on a spindle sander. The outside becomes a mould template if I need it and the inside becomes a bending form template.
PostPosted: Wed Mar 27, 2013 6:48 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I do mine same as James. I make the outside mold and the bending form from the mating pieces of plywood. I use my scroll saw to cut 3/4 inch birch plywood and then spindle sand each piece. Hadn't really given any thought to purposely making the bending form slightly smaller, I'm just cheap.
PostPosted: Wed Mar 27, 2013 9:14 am
Yup. I make my outside mold first, then trace inside it with a 1/8" sharpie, then sand the sharpie line til it's gone. More or less accounts for side width.
PostPosted: Wed Mar 27, 2013 10:39 am
Same here, but I usually go for .125 - .150 or so.
Thickness of side + heat blanket + slat, so it depends on what I'm building and how thick the sides are going to be.
PostPosted: Wed Mar 27, 2013 11:38 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I have a washer like Todd's but at about .150" so my bending form is that much smaller. I have never had issues with spring back that was excessive but sometimes have to touch up the waist and cutaway by hand. I really like Dreadnoughts as bending is so easy.
Fred
Fred Tellier
Users browsing this forum: Chris Pile and 77 guests
