It is currently Fri Aug 22, 2025 6:31 am
PostPosted: Mon Apr 01, 2013 12:04 pm
Last Name: Sollod
I have some cutoffs of alder and maple from solid body electric guitar builds. Can these woods be used for neck and heel blocks for steel string acoustics?
www.swiftcreekguitars.com
PostPosted: Mon Apr 01, 2013 2:36 pm
Yes, but they'll add a lot of weight...
PostPosted: Mon Apr 01, 2013 9:54 pm
Alder is generally lighter than Mahogany but they are pretty close. Good dense Alder is about like average or slightly light Mahogany but it is no where near as heavy as densest Mahogany.
I am trying to say that they overlap slightly in the upper densities for Alder and the lower densities for Mahogany.
Hope that makes sense.
L.
PostPosted: Mon Apr 01, 2013 11:05 pm
First name: Darryl
Last Name: Young
State: AR
I've wondered if Eastern Red Cedar could be used for neck/tail block (at least for a bolt-on).
PostPosted: Tue Apr 02, 2013 2:50 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I have heard of some using spruce for the blocks.
PostPosted: Tue Apr 02, 2013 7:52 am
Last Name: Hosmer
Been thinking about using laminated Spanish cedar.
Always have plenty of sandpaper; it's rough out there!
PostPosted: Tue Apr 02, 2013 8:18 am
Last Name: Ensor
City: Springfield
State: Missouri
I repaired an old Epiphone that had a balsa neck block once!!!
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Tue Apr 02, 2013 9:29 am
Last Name: Sollod
It sounds like maybe a lot of folks aren't using other types of wood for acoustic neck and tail blocks... Maybe most acoustic builders aren't building solid body electrics and don't have these scraps lying around. I haven't heard anybody say that it would be a big mistake to use alder of a bolt-on neck block (I assume the tail block doesn't matter). I hate to waste wood if I can help it. With the alternate woods being used for B&S and sometimes necks, seems like alternate woods could also be used for other aspects of the build. ...I'm not talking about balsa for neck blocks or alder for braces...
PostPosted: Tue Apr 02, 2013 10:22 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
I worked in a well known shop and spruce was used, I like it as a neck block and use good plywood from Hobby Lobby for tail blocks. Never a problem
PostPosted: Wed Apr 03, 2013 7:36 am
I use spruce for blocks, and also use WRCedar at times, but that wasn't the question....
