It is currently Sat Aug 09, 2025 3:38 am
 Post subject: Making a thumb pick
PostPosted: Wed Apr 03, 2013 11:05 am
First name: Carl
City: Portland
State: OR
I'm nearing completion of my first build and I decided I wanted a wider nut and string spacing for finger picking. The problem is I cut off my right thumb just below the knuckle on a table saw several years ago and a standard thumb pick won't fit over the stub. I can hold a flat pick just fine but finger picking eludes me. I was thinking if I could get some of the material used for finger picks I could maybe make one. Anybody have any suggestions?
 Post subject: Re: Making a thumb pick
PostPosted: Wed Apr 03, 2013 11:56 am
City: winnipeg
State: manitoba
Country: canada
Any finger-picks that I have seen are just plastic sheet wrapped around a mold. Make a mold of your thumb that will withstand heat to 250 degrees F and try it out.
Pickguard material might work. The time and temperature will vary with the plastic used and its thickness.
The mold may have to be made smaller to give you "spring" in the pick.
Post your results.
Bob
PostPosted: Wed Apr 03, 2013 7:32 pm
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Maybe you can check out the shark tooth and Kodiak picks.
http://www.strum-n-comfort.com
PostPosted: Wed Apr 03, 2013 8:40 pm
First name: Hans
Last Name: Judd
City: Winfield
State: KS
I once saw an old timer play with a thimble on his thumb for this very reason.
:D
PostPosted: Wed Apr 03, 2013 10:42 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
My grandfather experimented once and made one out of a plastic toothbrush handle.
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Wed Apr 03, 2013 11:38 pm
First name: Carl
City: Portland
State: OR
I just checked out the website. I think one of these just might work. Thanks!
PostPosted: Thu Apr 04, 2013 3:37 am
Blue Chip thumb picks have a metal part that goes over the finger, which can be bent and reshaped a bit to fit your finger. Perhaps they could be made to work for you. http://bluechippicks.net/
PostPosted: Thu Apr 04, 2013 10:17 am
Their picks are nice, too. I use the thumbpicks and flat picks. They last forever.
PostPosted: Thu Apr 04, 2013 12:56 pm
...or until you lose them :cry:
I really like them too, both for guitars and mandothings
PostPosted: Thu Apr 04, 2013 1:10 pm
Too true - they are expensive to replace.
PostPosted: Sat Apr 06, 2013 10:56 pm
First name: Carl
City: Portland
State: OR
Thanks guys for all your help. I decided to give the strum-n-comfort a try. They look like they will attach to my short thumb the best. The Blue Chip look nice but they are shaped like a conventional thumb pick so they wouldn't fit well and $40.00 is a little steep for a thumb pick.
Users browsing this forum: No registered users and 42 guests
