It is currently Wed Aug 13, 2025 10:27 am
PostPosted: Thu Apr 04, 2013 3:29 pm
First name: Ringo
I'm looking for some c-clamps for a crack repair... I need about an 8-9" throat, so 2-3" longer than Shop Fox bridge clamps. The soundhole is really small so my long cam clamps won't fit. I ordered some of these: http://www.harborfreight.com/8-inch-dee ... 45917.html which look cheap and ideal sized but they appear to be sold out. Any ideas?
PostPosted: Thu Apr 04, 2013 4:26 pm
First name: Tom
Last Name: West
State: Nova Scotia
How about these?
http://www.lmii.com/products/tools-serv ... ated-clamp
Tom
PostPosted: Thu Apr 04, 2013 6:01 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
If you knock the corners off the lower arm of a StewMac 8 1/2" cam clamp, it will fit in most classical guitars. Don't know if that helps you.
PostPosted: Thu Apr 04, 2013 10:55 pm
First name: Ringo
Hmm... for this guitar not quite but if I made a cam clamp with a curved bottom like so:
it seems like the arch would make it stiff and the curvature would make it easy to fit inside a smaller guitar. Does anyone make something like this?
PostPosted: Fri Apr 05, 2013 12:47 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I have those harbor freight deep reach clamps. They are heavy as hell and would probably cause more damage then they are worth. I tried using them for an acoustic and you could actually see the top flexing from the weight of them. Tom West had the same exact idea for a clamp that I had when I first read your post.
PostPosted: Fri Apr 05, 2013 9:29 am
First name: Ringo
Good to know about the HF clamps... I think I'll just make a curved-bottom cam clamp and see if that does the trick. The LMI clamp seems like a clever idea but looks very light duty... I need some pretty decent clamping pressure.
PostPosted: Fri Apr 05, 2013 4:02 pm
First name: Ron
Last Name: Belanger
http://www.stewmac.com/shop/Tools/Clamp ... lamps.html
PostPosted: Fri Apr 05, 2013 7:01 pm
First name: Ringo
Ah, perfect... how did I miss those before?
Users browsing this forum: dofthesea and 28 guests
