It is currently Sat Sep 13, 2025 12:36 pm
 Post subject: Epoxy pore filling
PostPosted: Fri Apr 05, 2013 1:01 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Okay I use the old style pore fillers like pore-o-pac still and it works well. I want to give the epoxy filling a try but have seen many mentions of Sytem Three or Zpoxy brands. Which ones am I looking for? There are various types that they each sell so what ones? Searching back post you see the brand names mentioned but not the exact ones. I have noticed in woodworking catalogs that system three sells a Mirrorcoat epoxy finish that's for bars and tables. Anyone tried this?...Mike
 Post subject: Re: Epoxy pore filling
PostPosted: Fri Apr 05, 2013 1:06 am
Last Name: Flindall
City: Peterborough
Mike, I used the Zpoxy on my last two guitars to pore fill and I loved it. Your looking for the Zpoxy finishing resin. It'll say PT-40 on the box, which I believe is their product number. I can't comment on the other as I've never used it. But you can't go wrong with the Zpoxy.
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Fri Apr 05, 2013 1:17 am
First name: Trevor
Last Name: Gore
City: Sydney
WEST is an option. Have a read of this.
http://www.goreguitars.com.au
PostPosted: Fri Apr 05, 2013 4:21 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use system 3's sb112 with the fumed silica filler. I like it because it is near water white, z-post is not. It its sensitive to proper mix ratio though, more than the others.
Brian
PostPosted: Fri Apr 05, 2013 8:32 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
If you are in a rush Z-poxy is the quickest cure before sanding can be done. West and System 3 are a fair amount slower, I found that 24 hours between coating and level sanding was a safe cure time. As you will see in some of my comments in Trevor's link my current preference is West 105/207. If you are happy with the product you are using why change, I personally have not yet found a product that I love, but at least for me the epoxy products are less messy and less bother than the other fillers I tried
Fred
Fred Tellier
PostPosted: Fri Apr 05, 2013 7:21 pm
Last Name: Shaw
City: Phila
State: PA
Thanks guys!...Mike
PostPosted: Sat Apr 06, 2013 7:06 am
One caveat when sanding epoxy. Uncured epoxy is more of a sensitizer than fully cured epoxy. I do veneer laminations with West system epoxy and have found it best to leave them in the form for a week for greatest stability. I believe it takes this long for the epoxy to fully cure. If you are sanding epoxy fills after a day (which most of us do) it might be a good practice to avoid the dust.
I could be wrong on this, so if someone has better information, please feel free to set me straight.
PostPosted: Tue Apr 09, 2013 9:40 am
First name: Corky
Last Name: Long
City: Mount Kisco
Sounds like very good advice to me. I've also heard that the epoxy hardener in particular is very toxic, so use the proper logical safety precautions; nitrile gloves, proper ventilation, etc.
PostPosted: Tue Apr 09, 2013 10:53 pm
Last Name: Conery
I am having very good results using Z-poxy finishing resin in two coats: a wash coat of shellac, then full strength for the first Z-poxy coat, sand back to wood (try to not pull the Z-poxy out of the pores, i.e. sand lightly), another wash coat of shellac, then the second coat of Z-poxy thinned with some ethanol, sand back again. Works like a charm. YMMV. Good luck.
http://coneryguitars.com
Kill your television!
